First post, by kmikze
Hello people,
I recently disassembled a Toshiba Tecra 510CDT (P133 Mhz) and I was wondering if this CPU needs thermal paste?
It has like 2 sets of heat sinks. Between the heatsinks there is a pink thin layer of some material. I attached some photos so you can have a better idea.
What do you think it will be the best approach of putting this back together?
Thank you
    1.05 MiB
    the naked CPU
    856.82 KiB
    the heat sink side where it touches the CPU
    1.2 MiB
    there is another heatsink under (there is a pink layer in between)
    1.19 MiB
    the first heat sink
Reply 1 of 1, by kmikze
I'm asking about this because I checked on a desktop PC with an Pentium-S 120Mhz, and strangely enough it doesn't have a thermal compound between the CPU and the heatsink. The Desktop-PC is from 1995 and it had files on its drive from 2001, so it worked like that those years:D
Well, I think I will apply a thin layer on this one with thermal compound, to be on the safe side, it can't do any damage. I am not sure about the pink layer on the bigger heatsink, wouldn't be better to remove it or to apply over it also some thermal compound?
