First post, by amijim
Hello Vogons, once again the quarantine has given me the time to play with my upgraded Qube 3.It is running a low wattage amd k6-3+ at 600mhz core ACZ and 1gb ram and an Intel pci 1gbps nic an 40gb HD for OS and 300gb HD for my data. I installed the strongblot version of Centos 4,5 updated to 4,9 final, installed 2.6.36-2 kernel from DavesWorlds RaqCop channel, installed webmin, samba and mini dlna and i have been live streaming 3 HD movies silmutaneusly. Long live the retro world! For any question feel free to contact me.
    1.72 MiB
    981.36 KiB
    872.49 KiB
    1.29 MiB
    63.02 KiB
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 1 of 1, by ragefury32
Ah yes - did something almost the same on my Qube 3, except mine is running Debian Jessie....It's old, but not that old.
87.27 KiB
Webmin
The kernel has been updated to 3.4.8 - was working on a 4.17 kernel earlier but it ran into a build issue (related to Debian bug 848066) so it was back to the 3.4.8 for now.
1.15 MiB
LCD Display
Whats inside? 450MHz K6-3+ (Sharptooth) - mostly so I can manage the power consumption with clock-back on idle, 1GB of PC100/133, 2 NatSemi FastE NICs, and a Promise SATAII dual port controller (yeah, I know, good old 32 bit PCI is not enough to run a single SATA150 port, much less 2 SATA300...of course, dealing with hard drives, it's plenty enough).
106.92 KiB
Linux Specs
I did swap out the original Delta fan for a SileX 60mm fan with rubber mountings that ran much quieter, and the primary drive on IDE0 was replaced by an 8GB industrial IDE44 drive, and then by an IDE44-to-SD adapter simply because digging a bad kernel build out and fixing it on my linux machines take much longer with the industrial IDE (I'll need an IDE-to-USB adapter) than with the SD.
1.24 MiB
What's inside
What's the long term plan for it? Probably not much - the machine was long replaced by my HP MicroServer G7/N40L (which is currently my RAIDz10 array), which in itself is old enough to be considered retro. The computing end is already supplemented by a Ryzen embedded box on top. I could toss a few old SATA1 drives in there to make it a ghetto NAS, but eeeeeh, why bother.
69.83 KiB
HP t740/MSG7 N40L
