First post, by auron
to quote the driver readme for these S82557-based cards:
wrote:EtherExpress PRO/100B TX adapter: Supports auto-negotiate, full and half duplex at 10 or 100 Mbps. […]
and half duplex at 10 or 100 Mbps.EtherExpress PRO/100B T4 adapter: Supports full and half duplex
at 10 Mbps; supports only half duplex at 100 Mbps. Auto-
negotiate is not a valid option at either speed.
so, is there a proper way to find out which version one has? i might possibly be answering my own question here but on the card i have, next to the "LNK", "ACT" and "100" cutouts there is also "TX" engraved but no cutout and there's a transistor on the board instead of an LED, so i'm assuming my card might be the T4 version.
this difference really doesn't matter much when using these things just for unidirectional file transfers these days but it's quite astonishing how they sold a gimped version under basically the exact same name - i've never even seen that T4/TX referenced before reading this file and the driver doesn't seem to mention it anywhere either, at least the one that comes with 98se.
