First post, by ajdrenter
I've recently acquired a P55T2P4 for really cheap for parts and I've built a 233MMX system with it. This board is the 256KB PB model with a COAST slot. When I set the jumper for 512KB and insert a coast module, none of the L2 cache shows up. If I boot up without the coast module and with the L2 enabled, the motherboard will hang after post, right before trying to boot a boot device. If I disable the External Cache in setup, the motherboard will once again boot and work properly. I flashed the latest BIOS, with the 128GB HDD support, before I realized the cache wasn't working. Has anyone ever had this problem, and if so how did you solve it?
