First post, by FXing Serious
Hello,
I need help to determine if this PC133 RAM is compatible with my motherboard (Chaintech 5RSA2-2): "128MB Third Party MEMORY 16X64 168 PIN PC133 6NS 3.3V NON ECC SDRAM RAM DIMM". It's all it says on the eBay listing. I have attached a snip of the motherboard manual too. Thanks
    87.91 KiB
Reply 1 of 6, by weedeewee
considering it says EDO in the DIMM type line, I'd say, nope, not compatible.
Though there's always a chance I'm wrong.
Do not ask Why !
Reply 2 of 6, by pentiumspeed
Yes, it does take either EDO in this stick format or SDRAM (says so Synchronous DRAM).
Try the PC133 stick and see what it boots, it will run at 66 or 100 depending on your FSB is set for given processor.
Cheers,
Great Northern aka Canada.
Reply 3 of 6, by weedeewee
pentiumspeed wrote on 2021-04-28, 18:10:
Cheers,
Dangit you're right. 😀
Do not ask Why !
Reply 4 of 6, by FXing Serious
Cheers,
So if I am understanding correctly if the FSB is set to 100 then a PC100 128 ram would be all I need since it relies on the FSB.
Reply 6 of 6, by weedeewee
FXing Serious wrote on 2021-04-28, 19:40:
Cheers,
Well, yes, though with a PC133 module, there will be a higher chance that you can set the memory timings on your motherboard to the fastest possible and gain a little bit more performance.
Do not ask Why !
