First post, by Nexxen
- Oldbie
Hello everybody.
I just checked this unit but it gave me a strange result,
whenever I insert the only disk that I have it tries to read it a couple of times (clack clack) and then stops.
Can't be formatted as it fails with "disk is unusable".
It doesn't try to read it and doesn't go past those two attempts, hence no idea if this is a click of death situation or just a failed disk. No continous clicks.
I tried "trouble in paradise" software and it says z-tracks fail, all 4 tracks are unreadable. Explanation is a bad unit bricked the disk and is now dead forever or the unit could be faulty or both 😀
As my experience with not working zip stuff is limited (only working usb/lpt/ide),
is this a failed drive or a failed disk?
Thanks for any help.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
