First post, by Scythifuge
- Oldbie
Greetings,
I am experiencing a perplexing issue. This PC is hit or miss when it allows my floppy drives to work. I have a 1.44 3.5 drive, and a 1.2 5.25 drive connected to my Asus P2B (last beta bios.) After messing around, I was finally able to read 3.5 disks and I was able to format a 5.25 floppy and save a test text file to it. I had a CD/IDE adapter as the master and a 128GB SSD as a slave. I decided that I wanted the SSD to be the master so that I could use different CF or CF/SD adapter cards in this machine. I switched things around and reinstalled Windows 98SE and installed the latest chipset driver.
Now, when in Windows, whenever I try to access the 3.5 drive (any floppy,) I get a "disk isn't formatted" message. This also happens with the 5.25 drive. However, I get an error if I attempt a format. If I exit to MS-DOS, I can read the contents of a 3.5 floppy, but I get an abort, retry, fail if I try to access the 5.25 drive. This crap was happening before, but I had finally got it to work, even after multiple reboots/power cycles. I tried changing the cable and I am getting the same error.
I though maybe the floppy controller was going bad (I have seen this happen on other mobos,) but it doesn't make sense - it should either work or not. I shouldn't be able to read in MS-DOS and not Windows. I am going to try to reset BIOS to defaults and set it all back up, though I don't think that that will do anything.
Any ideas? I am at my wits end and am getting really frustrated with this nonsensical situation - everything works, then it doesn't, then partially works but only in MS-DOS, not WIndows... I may try a Tabor II board, but I don't know if it works, and it is inadequate for what I am doing and thus I need a P2B or similar mobo for this project. I may order an ISA floppy controller, though I was hoping to have that slot available for a NIC.
Scythifuge
