First post, by Half-Saint
- Oldbie
That card can have one or two poor quality capacitors (was it KZE or KZG?) Those cans usually dries out, although they were fine in my card. Maybe a good point to start from.
Someone please show Putin how to play Warcraft.
fool wrote on 2021-05-18, 17:45:That card can have one or two poor quality capacitors (was it KZE or KZG?) Those cans usually dries out, although they were fine in my card. Maybe a good point to start from.
Thanks, will swap them out for new ones from Rubycon or Panasonic and see, if it helps 😀
It's also could be a bad ram chip and if it's a bridge card the PCI-e to ago bridge could need some active cooling
Yes, the original caps are KGZ. I finally got to replacing them with Panasonic FK caps today. Unfortunately I ordered two instead of three caps. Now the video output looks even worse but maybe it also has something to do with the fact I'm testing it in a different motherboard than last time.
BTW, attached a photo of the card itself (taken before the recap). The cap closest to the heatsink is still the same.
Mind telling me which board you're using it with? I have cold boot issues with my nf3 s754 board.
sirotkaslo wrote on 2021-08-02, 11:14:Mind telling me which board you're using it with? I have cold boot issues with my nf3 s754 board.
Sure, it's Gigabyte GA-6VTXE.
Thanks
