First post, by Scythifuge
- Oldbie
Greetings,
I was struggling to get an NEC CDR-273 quad speed to work in a Tomato 4DPS board with a slaved Teac DVD-ROM, explained in this thread:
4DPS replaced, but of course there are woes
I finally got them both to load with VIDE-CDD.SYS, simply after trying a longer cable. There doesn't seem to be any other explanation. I did find a thread I made back in 2016 where I had similar issues trying to get two drives to operate, though I forgot about it as that was before my accident (and when I had an easier time with such projects!) I used the same CF cards with the same files that I had when I solved that issue, so it is strange that I experienced the issue again, albeit with a different solution.
However (of course...)
Whenever I put a disc in the NEC, the computer reboots as soon as the door closes after the tray slides back into the drive. If I leave the disc in the drive, the mobo will post with a beep, and then reboot - over and over and over. If I open the door while booting, it will complete the boot process. I love this Tomato board (it has been my favorite socket 3 board due to PS/2 mouse support and PCI slots,) and spent a year or two hunting down a replacement. I have seen the CDR-273 mentioned in other threads on Vogons as a good choice, and I would love to have a quad speed drive for compatibility with certain games.
What I really need is to figure out how to get the 1.72f bios on a chip that is compatible with this board...
I got this drive to work as a lone secondary master. What could be causing the drive to reboot as soon as the tray closes with a disc inside? This is a new one for me...
Scythifuge
EDIT: I swapped the drive out with another driver as the master and kept the DVD as a slave, and the rebooting persists.
