Hiding disks
First post, by Velociraptor
Typically when I install an OS I will remove all drives in the system apart from the one I'd like to use. That means I don't run into any problems with boot stuff going onto the wrong drive.
However I now have 4 midi towers beside each other, connecting into a mixer, a KVM, switch, midi switch etc and it's really inconvenient to open one up and unplug a drive when I want to install an OS.
I thought I had the answer last night by changing the main BIOS screen to "not installed" for the IDE channel of the disk with the Win98 install on it I wanted to make sure wasn't affected when I installed XP onto the other disk. So in the install, confident I'd done it correctly I just got rid of all partitions it showed. And of course you've guessed it, removing it in BIOS wasn't enough, Windows still saw it and I got rid of 98! No harm done, no data lost it was a fresh install.
Does anyone know of a way to do this without opening the machine? Or is there a way of achieving the same effect with certainty - making sure that each install remains restricted to it's own drive?
Reply 1 of 14, by weedeewee
yep, switching the autodetection off in the bios is definitely not the way to do it.
disabling an IDE port/controller might work, though that would mean you'll lose two devices at once.
having a manual switch on the power lines of the hard drives will work, though can sometimes give problems with autodetection due to master, master with slave, slave, cable detect annoyances.
swapping hard drives using a drive bay would be ideal, though that takes up a 5"1/4 slot for each drive you want to be able to swap and end up becoming a logistical nightmare when you have many drives to swap around for each machine...
Choose your poison.
Do not ask Why !
Reply 2 of 14, by Errius
If you have spare 5.25" bays then some sort of removable drive system is the way to go. I like Icy Dock units, but those are expensive. You can also find cheaper clones in the usual places.
Is this too much voodoo?
Reply 3 of 14, by BitWrangler
Yah, you might wanna hit up Ali Express for a box of 10 or 20 or something.
Reply 4 of 14, by Errius
BitWrangler wrote on 2021-05-22, 21:49:
I was lucky to cheaply get a box of MB123AK units from a guy who had just switched all his office computers from PATA to SATA.
Reply 5 of 14, by Velociraptor
weedeewee wrote on 2021-05-22, 20:37:
yep, switching the autodetection off in the bios is definitely not the way to do it. disabling an IDE port/controller might wor […]
Choose your poison.
I don't like any of those options, sadly. I'll have to think more on this. It may depend on what I'm going to do for imaging the drives. It may be that I won't reinstall the OSs I'll just image them back.
Thanks for all the suggestions though, it seems the long and the short of it is that there's no real way to do it without physically disabling the drive.
I will experiment with changing boot order first. However I think that can lead to XP installing to the D: drive, which is useless 😀
Reply 6 of 14, by weedeewee
Velociraptor wrote on 2021-05-23, 01:01:
Enjoy your descent into madness 🤣
edit: you might want to try software solutions, like System Commander, it changes partition ids to hide one OS from another.
Do not ask Why !
Reply 7 of 14, by Velociraptor
I didn't expect changing, hiding or temporarily removing partitions to work.
Windows XP for example today insisted that the primary disk have a compatible partition so it can put the boot loader on. It wouldn't continue without it so even if I did manage to conceal the partition it would still fail, I think.
Which led me to learning something - it looks like whatever I do in BIOS only lasts until BIOS hands over to the OS. So regardless of the boot order I select, regardless of the disks identified it doesn't matter, once it gets to the OS install section the list is reset and it will want to do something to the first disk on the list.
This may be fixed later along the line with UEFI for all I know, but it's not relevant for the purposes we use on these boards!
That means there's only three ways to do it that I can think of.
* Physically disable/remove/unpower the other disks
* Install onto the first disk in the system and then image onto another (this could cause problems perhaps)
* Install onto second disk, let it create the mess on the first disk, clean the mess and then fix the boot loader somehow
The 2nd and 3rd options could introduce more problems than they're worth so I've got the side of the machine open now, as annoying as it is, because that way I can be sure
Reply 8 of 14, by weedeewee
no uefi will do nothing for it.
changing the disc partition types has always worked, since no os would risk... (ahum) to open, access, read or write to an unknown partition.
it get's even better when your boot drive isn't your 'first' drive according to the os.
Do not ask Why !
Reply 9 of 14, by Velociraptor
Yes, but XP won't install unless it can create a boot loader on the first drive according to the OS. So the entire drive needs to be hidden not just the partition.
Reply 10 of 14, by dionb
I'd suggest a low-tech electronic solution: put a 4-way switch onto a blank 5.25" plate, then wire the GND for the drives through that switch. Set to desired position before boot and enjoy a single working drive.
Reply 11 of 14, by weedeewee
dionb wrote on 2021-05-23, 14:03:
GND? surely you mean the voltages 5V and 12V.
Do not ask Why !
Reply 12 of 14, by Velociraptor
Something like that could work. And perhaps when I strip them down I'll do something. I'd want to be able to enable/disable each drive as I only need them to be gone for when I install the OS, after that I can use Plop! to boot properly.
Reply 13 of 14, by debs3759
weedeewee wrote on 2021-05-23, 14:42:
That would be my thought as well. Drives will always be grounded by the case.
Reply 14 of 14, by BitWrangler
Can you hijack the drive ready line or something.
