First post, by Scythifuge
- Oldbie
Greetings,
Having settled on PCI/ISA card configuration for my Ultimate Retro Rig project, I began to install a different OS to SD cards (Windows 98 on one,95 on another, WFW/MS-DOS, Linux, etc.) Windows 98 detects my VIA based PCI USB card as a Via 3038. I found drivers for the card, and they installed without a hitch; no splotches under device manager. However, I have tried connecting a flash drive, a card reader, and a gamepad to each of the ports on the USB card, and it none of them work - it seems as if the ports are dead or that Windows is ignoring the fact that a device was plugged into the card. The integrated USB on this P2B are working fine. I even found a cable with dual USB on one end with male header pins on the other, and routed the mobo USB 1.0 ports to the front of the case. Those ports detect gadgets that are plugged into those.
So either there is some compatibility issue with the VIA card, or the ports are actually dead. Are there things that I can try, or should I replace the card? If I need to replace it, what USB 2.0 cards are known to work on an Asus P2B? I would like it to be a small card. I have this one in the first PCI slot beneath the AGP slot, and the low profile card allows for a lot of open air space for my Voodoo5 5500 fans.
Thanks!
Scythifuge
