First post, by metrox
Found this card in an old 286 but have no idea what it is, does anyone have a clue?
Here is the link of the images.
https://imgur.com/a/56rg0ag
Proprietary Mitsumi CD-ROM card. More or less junk.
I haven't seen them in 8 bit.
Even the cards for the LU005S and FX-001D were 16 bit ISA.
But it is an adapter for CDROMs.
Chances you'll find a working matching drive for little money are slim.
If so, it probably comes with a controller card already. And those drives tend to be a bit more problematic using burners CD-ROMs too.
Stuck at 10MHz...
Disruptor wrote on 2021-07-01, 10:50:I haven't seen them in 8 bit.
8b is interesting - which IRQ does it use?
What's a bit more interesting is that it has the external drive connector. There used to be a lot of those booting around for cheap because nobody could use them. IDK if they would suffer damage though if ppl mistook them for 25pin SCSI and plugged them to that. Some of the externals seemed a bit more durable than the more "commodity" type internals.
