First post, by squ1rrel
Hi all! I've installed Windows 98 on a Compaq Armada 7800 following my last post, which enabled me to play DOS games with support for the SB-compatible ESS1879. However, I seem to run into games being ever so slightly slower than they should be, mostly noticeable only through audio, and weirdly enough the speed seems to pick up if I have the BIOS video scaling enabled (Fn+T). I've tried this running the game plain while in Windows 98, and also by rebooting into MS-DOS mode, both show the exact same symptom. I don't have a working FDD for the Armada right now to try a plain 6.22 install, or to install the Compaq rescue disks which give me access to a CMOS configuration tool (these laptops had an external tool that would reside on the first partition on the hard drive, the BIOS is completely unconfigurable otherwise). Does anyone know what could possibly be happening here?
Here is a link to a tweet with a video showing the issue, apologies for the poor composite video quality, I'm still waiting on another capture card.
