Varta's out. Now what?
Reply 20 of 24, by britain4
With a 1N4002 in series I get about 4V to the board from 3 AAAs
- P-MMX 200MHZ, PCChips M598LMR, Voodoo
- P-MMX 233MHz, FIC PA2013, S3 ViRGE + Voodoo
- PII 400MHz, MSI MS6119, ATI Rage Pro Turbo + Voodoo2 SLI
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500
- Toshiba Libretto 110CT, 300MHz, 96MB RAM
Reply 22 of 24, by britain4
Indeed, works a treat so far!
Reply 23 of 24, by douglar
I recently acquired a board and the seller had replaced the Varta battery with .... another NI Cd battery! It's not a Varta though.
Will it likely leak?
506.79 KiB
Reply 24 of 24, by Trashbytes
douglar wrote on 2024-04-05, 01:54:
perhaps in 20 years it might, but if its a good quality one that is actually new then ..that might be 30 years or never.
