First post, by DerKammi
After lurking a good while here I'm finally stuck at a CPU Soft Menu of my Abit BH6 V1.2.
Bit of history of the board. I bought it dead, won't POST. Recapped the board with some new Panasonics and just in case bought a freshly flashed BIOS with the latest BIOS.
Still didn't POST so I started poking around the board with a probe and found some cold solder joints on the PLL chip. After some soldering the board was revived and booted al the way to the no-OS point.
So all in all pretty happy. Installed my IDE2SD device and a VMWare loaded SD with Win98SE installed. Booted fine 😁 Very Happy.
Then my issue. I bought kind of a gamble with a PIII 533 Coppermine with the 133 FSB. So it ran fine but at 266MHz 🙁 So 66FSB.
Back to the BIOS and changed the CPU settings in the CPU Soft menu. But no setting is changing my clock speed at all. Tried a couple off FSB settings 83, 100, 103 at 1/3 PCI and 126, 133 at 1/4 PCI. All with 2/3 AGP divider.
So the CPU is stuck at 266 whatever I set the BIOS at. Attached is a photo of a message I get at boot when I change something.
I don't have an other CPU to test some more. Hope someone has some tips
