First post, by romtos
the Silver-Reed EX44 has a front-panel edge-connector, which was used e.g. for the M40 "Memorymatic". And there was a RS232 adapter available for it.
Of course, this is unobtainium today, I can’t find one, but I’d love to connect the typewriter to a machine of the same era, via RS232 serial port. Does anybody know how to connect it? And/or the pinout of the edge connector?
Regards
Götz
Reply 1 of 4, by BitWrangler
All I'm turning up are a lot of forum threads that start like this one and don't really go anywhere. There is mention that these are an "Olivetti copy" I don't know whether that means a work-a-like, unauthorised reverse engineered thing, like a compaq was an IBM PC "copy" or whether they mean it was licensed manufactured or badge engineered identical.
Reply 2 of 4, by snufkin
Probably doesn't help much, but here's a scan of the I/F44, which was apparently a parallel port adapter: https://etzone.org/2021/04/12/silver-reed-i-f … erating-manual/. Looking on ebay turned up a Memorymatic M44, which the photos show as having a 26 core ribbon cable going from the M44 to the EX44. I'd guess the edge connector is some form of parallel port, with the I/F44 acting as a character set translator. I haven't found anything about a serial interface though.
Reply 3 of 4, by romtos
snufkin wrote on 2021-09-01, 10:51:
I own both the typewriter and the Memorymatic M44, which adds some "macros" functionality to the typewriter.
I’d like to connect it to a computer, though (preserving the Memorymatic, of course). I’d be happy about a parallel port, too, I just wasn’t aware of it and therefore asked for a RS232 version. Would be happy with anything 😀
Reply 4 of 4, by snufkin
I've had a look around and can't find any documentation of the port on the EX44. My guess is that it'll be some variation on a standard parallel port, but given the functionality of the M44 then the port must be bi-directional. From a quick read around the PS/2 had a bi-directional parallel port in 1987. The manual for the M44 is copyright 1982, so before there were any standards for bi-directional.
It should be possible to work out how the port works, but I think it'll need a bit of work either looking at the circuit boards, or using a multimeter (or logic analyser) on the port, or both, to work out what the pinout of the port is and how to make sure the EX44 is in receiving mode.
