First post, by jal
I've recently booted up my old Pentium MMX with dual boot Windows 95/Windows 2000 to backup some very old stuff. It has a network card, but somehow the drivers aren't installed (I swapped hardware apparently), so the only way to get information on and off is floppies. I've bought a USB floppy drive for my Windows 10 laptop (Mitsumi), and had hopes to be able to exchange data. Unfortunately, I ran into trouble.
First, most floppies I have (I still have two full boxen) don't read in the USB floppy drive, I get "The disk media is not recognized, it may not be formatted." errors. Some work however. All floppies are readible in my old machine. The floppies that work in my USB drive get unreadible ("disk media not recognized") as soon as my old machine writes to it (or sometimes just accesses it). If I write something on a working floppy with the USB floppy drive, it isn't readible in my old machine (I get copy errors, or "error performing inpage operation" errors.
So I'm a bit at a loss what to do. It seems to me the USB floppy drive is bad, but if so, what to replace it with? It'd very frustrating that I only have to transfer 30KiB for the RTL driver to get the network card working, after which I can try disk sharing or FTP or the like. Any thoughts?
EDIT: I just tried to copy files off a readible floppy with the USB drive, but halfway of copying a file, it gives me a "disk media not recognized" error again.
JAL
Reply 1 of 13, by Thermalwrong
Which OS? My USB floppy drive just started doing something similar to this a couple of weeks ago, on my main PC with Windows 10. But the USB floppy drive works fine on one of my Linux laptops.
The disk I'm testing with is a Win98 bootdisk that works fine in all floppy drives on old PCs, I've tried several other disks as well though.
From what you've described, you may have a different problem. It sounds like the alignment of one drive might be different from the other. Probably best to test with another floppy drive so you can determine which of the two has bad alignment.
Reply 2 of 13, by Joakim
I don't know, but the usb floppy drive needs might just be dirty. reading old floppies can have that effect I heard. Dirt, dust and oxide you know.
Personally I don't think it is alignment if you fail to write on the usb drive.
Actually tried to copy something similar the other week but I ended up giving up and burning a cd with an usb Lenovo dvd writer..
Reply 3 of 13, by Zup
Many USB floppies only read standard 1.44Mb floppies. Others can read both standard 720Kb an 1.44Mb.
Excluding special hardware like Kryoflux, I don't know any floppy that can read not standard floppies (i.e.: floppies with 10 sectors/track or with odd sector numbering). So don't expect reading copy protected disks.
I'm selling some stuff!
Reply 4 of 13, by jal
Thermalwrong wrote on 2021-10-06, 21:06:
Which OS?
I tried both Windows 10 and Windows 7.
Mmm, I have an old Linux laptop I could try, thanks for the idea.
Given that my old Win2K PC can read all floppies I feed it, but the USB floppy drive can't (even official disks), I highly suspect it's the USB floppy drive that's off. Weird though, back in the days I never had problems reading any 3.5" floppies. Maybe the USB floppy drive is just botched...
Joakim wrote on 2021-10-06, 21:26:
Well, it's brand new, just bought it.
It doesn't fail to write, but what's written fails to read on the Win2K machine.
Zup wrote on 2021-10-06, 21:45:
These are all 1.44MB floppies.
I was only suspecting to copy something on a floppy and read it on my old machine 🙁.
JAL
Reply 5 of 13, by jal
Ok, small update: I tried the USB drive on Linux, but though it mounts, trying to read the floppy hangs the process (drive light constantly on, waiting mouse pointer). So I guess it's the external drive that's not good.
Reply 6 of 13, by Nemo1985
Yeah those external drivers are very cheap. I bought one from aliexpress a couple of years ago and it never worked fine, I had your very same problem.
Then I found there are adapters to use the old floppy drives with usb, since then I use it without any issues with windows 10.
Reply 7 of 13, by cyclone3d
If you want a real USB floppy, there are a few good ones I can recommend.
Dell - These come in both plain USB and also the laptop module type which can be hooked up via USB.
Any of the ones that claim 2x speed. They all use the same drive inside them. (Mitsumi D353FUE or a variant). I had a SmartDisk branded one of these I bought new years ago.. lasted at least 5 years. Then the one day I went to use it and it wouldn't read disks anymore. Come to find out one of the heads had come loose and was flopping around in the drive. Not sure if I dropped it or what happened. Ended up ordering another 2x floppy drive to replace it.
One I cannot recommend for use in Windows 10 is the Sony VAIO models. They will not work with Windows 10.
All that being said, I use a few different drives when making images of 3.5" floppies. Some drives will read some disks while other drives will read other disks. Just because a disk will not read in one known good drive doesn't mean it won't read in another drive.
Yamaha YMF7x4 Guide
Reply 8 of 13, by jal
Nemo1985 wrote on 2021-10-07, 13:02:
That's interesting, since I have a load of old floppy drives in my drawer. What kind of adapters are they? Are they easy to come by?
JAL
Reply 9 of 13, by cyclone3d
jal wrote on 2021-10-07, 14:15:
JAL
Yeah, just do an eBay search for:
usb floppy adapter
They can be had for a bit less than $10 US shipped from China if you don't mind waiting forever and a day for it to be delivered.
If you buy one for around $11 US, then the shipping time comes down.
Yamaha YMF7x4 Guide
Reply 11 of 13, by Nemo1985
JAL
I bought it from aliexpress, some time ago, do as cyclone3d said, you will get it right.
Reply 12 of 13, by weedeewee
Depending on the interface of the USB floppy drive, you could directly exchange it with any other normal floppy drive, or it might need a small adapter board, or if you have a laptop floppy drive you could use that. YMMV.
good luck.
Do not ask Why !
Reply 13 of 13, by jal
In the mean time, I have managed to get a 2nd old PC (but a lot less old than my Win2K one, viz. a Celeron D with Windows 7) up and running, and it has no problem reading all of my old disks, nor does it have a problem exchanging files per disk with the Win2K machine. So I've sent the USB floppy drive back to the shop as defective. Thanks all for the replies.
