First post, by ModemBlaster
I found a motherboard (an ECS P6BX-A+) and it has a BIOS update to support >40GB hard drives. However, the update is only supported on 2MB BIOS ROMs; this same board can have either 1MB or 2MB. Could I simply pop in a different size ROM if I get a 1MB board? If so, what exact chip do I buy?
Reply 1 of 5, by Repo Man11
The one I linked to in the thread should also work in your motherboard, but check the data sheet to be sure. What EPROM chip is a 256K compatible replacement for the 128K Intel P28F001-BXT-120?
"A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it." - Jack Handey
Reply 3 of 5, by ModemBlaster
Could something like this work assuming it has the correct pinout?
https://www.ebay.com/itm/M27C2001-10B1-2Mbit- … cs/293606048979
or
https://www.ebay.com/itm/STMicroelectronics-M … pc/150764047042
Admittedly I'm not too sure about these sorts of things, so I could be totally wrong
Reply 4 of 5, by retardware
Don't use EPROM, its programming works totally different.
The first one (EEPROM) should work. But you can also take any used 2Mbit chip for this which you salvaged from a dead/useless mobo.
