Reply 20 of 28, by Al_bundy
I try it with an sis chipset now. But its not comfi. a lot of blackscreens -> Elitegroup K7S0M
Horrible board... If it really works, i try it with the Biostar again with a new driver.
Amazing shit. I knowed bfor i start to build this pc, it will be horrible.
4x Win98 setup... a lot of freezes and bluescreens, but finally i installed all.
I really hate the Sischipset.
But finally the MIDI in Blood works. Also FX Sound. Without some settings.
Just install the driver and start the Game.
So... i have to try a new driver with the nforce board.
But i guess it will not work 🙁
The new Drivers dont works.
I have more chance under DOS?
Ok, dos didnt works too.
Wich Version of Dosbox (X) u recomment?
Windows 98SE, Athlon XP 2500+ ( underclocked @ 1Ghz), 512MB- RAM DDR1
Thank u and best regards
Ok, i tried it with a SIS chipset. It works. so Nforce dont support MIDI.
Seems like i have to change the motherboard, even its not really an option.
I didnt found a perfect board. But if i have a try, then with the VIA P4XB-M VA536.
Somebody knows the CPU support of this board?
I need minimum 2Ghz, but a TDP under 50W.
If a CPU is available i will have try with it.
https://www.ebay.de/itm/255110962391?hash=ite … okAAOSw6bNhKPDV
Al_bundy wrote on 2021-12-26, 13:04:Ok, i tried it with a SIS chipset. It works. so Nforce dont support MIDI. Seems like i have to change the motherboard, even its […]
If a CPU is available i will have try with it.https://www.ebay.de/itm/255110962391?hash=ite … okAAOSw6bNhKPDV
Here is the user manual:
https://www.manualslib.com/manual/632466/Via- … es-P4xb-Ma.html
So, iam not done yet. Midi works in Blood, but Carmageddon dont find a Midi device.
I would start the Games in Wind 98 SE. Actually the Sockel A system and Sis chipset works fine.
I have a question.
Is this right what i wrote in Paint or not to finish my project?
Does Carmageddon have MIDI support? It looks like it was planned, but the devs took it out and went with CD audio-only.
I dont know. Seems like its a rumor @ carmafandom 😮
They wrote that his ears r aching bcoz of bad midi sound and u cant turn it off.... 😮
I mean, i like my progress that in blood works Midi fine. But if Carma really works with Midi devices then i won my game what i play since 8 ears or so.
Maximum Soundcard compatiblity in Dosgames under Windows with PCI interface.
Remember, i started this project in the year of 2014
Alucryl - CNC - 3DFX - MIDIsound - Hifi - 100pix
