Reply 20 of 34, by Rikintosh
- Member
I think most of the instability problems boil down to old components, people don't care about the state of the motherboard capacitors, and depending on where you live, the board can suffer from very high temperatures, or too low, too much humidity or too little humidity, and that causes the capacitors to decay at different times and hours, and to different proportions.
I live in Brazil, and here it is very hot, and most people live in places with high humidity due to the proximity to the sea, it is quite common for me to find swollen capacitors, or leaked in equipment from 10 years old, sources ATX suffers A LOT (partly because of our terrible power grid full of noise), there have been cases of cards that weren't terribly unstable, but were a little "slow" for my liking, so I took out the capacitors, and measured some of them , I even found 2200UF capacitors that in the measurement had just over 300UF!
Also sometimes I find inductors that lost their varnish (due to the heat) and ended up accumulating oxidation (very common in coastal regions)
I believe that in North America, it is easier to conserve equipment, because houses are generally thermally insulated, and have a temperature and humidity control system, in addition to a cooler climate (even in regions like California, or Florida, due to most people use air conditioning). Here in Brazil air conditioning is a luxury item, and it consumes a lot of electricity, so only high-end people have one at home.
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
