First post, by Lylat1an
I'm preparing to rebuild/improve my Retro Rig, and one of the goals is to make it quieter.
Right now the loudest component is the power supply: Are three any quiet AT models, or would I be better off adapting a quiet ATX PSU?
Reply 1 of 10, by Sphere478
Mistel with adapter? 😀
Might need a voltage blaster though
I have that adapter and a 550w version of that psu. They work good! Only need voltage blaster if you need -5v
Sphere's PCB projects.
Reply 3 of 10, by Caluser2000
Just replace the fan....
Reply 5 of 10, by waterbeesje
You may also look into the few AT PSU for sale at Evercase.co.UK
These seem like modern, quality ATX PSU with some wire juggling and AT connectors, even with -5v
I don't have experience with them but they are probably pretty silent and reliable (looking at brands)
If you are attached to your current PSU: I second a fan replacement, noctua is my favourite is silence is your goal.
Stuck at 10MHz...
Reply 6 of 10, by MN_Moody
I would be careful just throwing a lower RPM fan into an AT power supply, at minimum pull the spec from the original fan and try to replicate CFM/static pressure as much as possible to maintain the same level of airflow with a high quality modern fan of some sort, reliability/longevity > quiet operation. AT power supplies are not as efficient as newer ATX models and can produce more waste heat, which if not expediently removed can further degrade already aging electronic components and lead to a catastrophic failure that could kill valuable or even irreplaceable components in your retro PC.
Reply 8 of 10, by dionb
Caluser2000 wrote on 2021-12-22, 09:58:
Yep, a nice Noctua Redux 80mm casefan does wonders (and probably moves more air than one with 25-year old bearings and grease)
Reply 9 of 10, by creepingnet
The Star PSU on my 486 is quiet, as is the J.D.R. MicroDevices XT clone PSU on my other 486 is also very quiet. You might be able to replace the fan with a quieter fan, or put the current one on rubber grommets to isolate sound a little more. At this point, first sign of PSU fan noise I replace the fan as when that goes, it's only a matter of time before the PSU cooks itself to death, also a good opportunity to clean out the PSU. I have also had luck pulling stickers and putting a drop of 3'n'1 oil into the motor shaft hole if accessible.
~The Creeping Network~
