Reply 20 of 22, by waterbeesje
- Oldbie
Disruptor wrote on 2023-12-21, 14:02:Basically the calculation is: 50 MHz --> 0 VLB slots (just one onboard device) 40 MHz --> 1 VLB slot 33 MHz --> 2 VLB slots 25 M […]
rasz_pl wrote on 2023-12-21, 12:41:50MHz VLB would be insane. Just pre VLB some manufacturers released 50MHz local bus graphics systems, but everything was soldere […]
50MHz VLB would be insane. Just pre VLB some manufacturers released 50MHz local bus graphics systems, but everything was soldered on the board. Example Re: Pre-VESA Proprietary 32-bit Local Buses?
May 1992 "Swan 486/33 DB, The blinding speed of Swan Direct Bus" with S3 86c911. CPU and graphic chip on a single, separate PCB daughterboard.
PC Mag 12 May 1992 https://books.google.pl/books?id=jcrsPJb76HAC … irect+local+bus
June Swan 486/50 DB running S3 86c924 at 50MHz
PC Mag 30 Jun 1992 https://books.google.pl/books?id=uummfdS7yF8C … local+bus+50mhzBasically the calculation is:
25 MHz --> 3 VLB slotsIt may be possible to add one VLB slot, but that is out of spec then. If you want to go borderline you even may try to run 3 VLB slots at 40 MHz.
Jujoba wrote on 2023-12-20, 21:52:Yes, it exist. And I have one in a socket 3 motherboard and working! I have had many troubles to make it work correctly. Sometim […]
Sometimes the mouse didn't work, or i have troubles with the video card, i put Windows 3.1, and Dos 6.22 and an adapter from MicroSD to Ide as a harddisk.
This Cyrix work with 5 VEven an empty VLB slot raises the capacity on the Bus. Perhaps this may cause troubles even if you don't use a VLB card.
Does your Cx486DX-50 run its cache in write through or write back mode?
So I've got a unicorn 😁
My Am5x86 runs at 50x3, with vlb i/o and vlb graphics (Trio32). It is picking in the vlb cards, so i get your point 😉
Honestly i still can't get why Cyrix would bother to bring out a dx50 at all. Lots of boards had proven to be unstable at 50MHz bus, while the DX2-66 was just as fast and perfectly stable with any half decent board.
Intel was the pioneer at this speed so I get why they hoped chipsets would develop along...
Stuck at 10MHz...
