[CLOSED] The Retro Web submissions thread: suggest edits and/or add new boards here
Reply 41 of 162, by GigAHerZ
https://www.ultimateretro.net/en/motherboards/6890
Infinity Multipro VII-386DXV
A better picture of it is here.
Through riser board, it has 3 ISA 16-bit slots.
It also has Bus Mouse port in front together with AT Keyboard.
The graphics card has both VGA and EGA (DB9) ports.
It can have cache, up to 256kB.
The JP14-JP19 is configuration for cache size. Yet again specifics are unknown, but trial-and-error approach can be used on those 6 jumpers.
It has (in its current configuration) 33MHz CPU with 66MHz crystal. So FSB is 33MHz. But i do have other boards with same chipset, that can do 40MHz. (Even 45MHz on another board is confirmed by me) But under CPU tab, i can provide nothing about 40MHz 386, but Intel 386DX-33 is working well. 😀
It has MR BIOS available for it - V020B324. (As MR BIOSes are based on chipset, not on specific board)
The integrated IO controller is 82C862 based, specifically UMC UM82C862F is on this board.
The SW2 and SW3 switchblocks control the integrated IO controller. While i don't know specifically, which one does what, then it should match all the capabilities here: https://www.elhvb.com/iocard/DLU-270.txt (And when i was playing around with the SW2 block, i was able to enable-disable serial and parallel ports and change addresses...)
The J5-J7 is Case Intrusion switch, Reset switch and Turbo switch. But i might be wrong with the order.
I recently also heared that it is a taiwanese machine that was brought to Estonia in the early years of regained independence. Unfortunately i haven't gotten any more interesting information...
    V020B324.zip
    47.49 KiB
    40 downloads
    MR-BIOS 1.65
    Multipro VII-386DXV.zip
    37.19 KiB
    43 downloads
    Original BIOS
    1.41 MiB
Reply 42 of 162, by Tiido
🤣, I saw that board on osta.ee just yesterday.
Reply 43 of 162, by GigAHerZ
Tiido wrote on 2022-05-27, 07:20:
Yes, the full machine is looking for a new owner there.
Before i will give it over to a new owner, i did want to put all my information out there to the public so we don't lose any valuable information. 😀
Reply 44 of 162, by GigAHerZ
https://www.ultimateretro.net/en/motherboards/8200#downloads
The 0A26 type bios patched with rom.by rom patcher 4.51.
CB-ROM that was required to make it work: 2.07
Reply 49 of 162, by Horun
Me too PC Hoarder. I think they are doing great at updating and modding pages when they can.
Reply 51 of 162, by PC Hoarder Patrol
Hi-res pics (front & back) - https://www.mediafire.com/file/gilu47lmhor4f0 … R_Pics.zip/file
for...
...Jetway J-913AF - https://www.ultimateretro.net/en/motherboards/9226
...Jetway J-530BF (Rev 2.0) - https://www.ultimateretro.net/en/motherboards/9102
Note that the layout is slightly different to the J-530BF pic already there.
Reply 52 of 162, by andunn
Boser HS-5000
https://www.ultimateretro.net/en/motherboards/11364
Dumped the BIOS image.
HS-5000 SIS 5571 VER:1.10
Bios date 07/15/95
Bios version 0626
    HS5000v22_AT29C010A.zip
    114.15 KiB
    39 downloads
Reply 53 of 162, by waterbeesje
For the Asus 486 SV2 r3.1 there is a pic with socket 3 present. My Board has a socket 2 present. Would that be something to add?
https://www.ultimateretro.net/nl/motherboards/9814
The image is a bit too big to post here but it's on my Dropbox:
https://www.dropbox.com/s/km78o58cppo7omh/Asu … 20r3.1.zip?dl=0
Stuck at 10MHz...
Reply 54 of 162, by Solo761
Manli M-MVP3
I recently got this motherboard, there's no record of it on Ultimate Retro, not much mention of it on the web, I only managed to find it on wayback machine
https://web.archive.org/web/20010208105441/ht … m.hk/cat11.html
It looks like this PCPartner board
https://www.ultimateretro.net/en/motherboards/6602
Main difference being it uses PLCC32 EEPROM for BIOS instead of DIP. Although I didn't try crossflashing the BIOS. Jumper settings are the same. I've tried Pentium 133 and K6-2 500 MHz, both worked fine.
I've dumped it's BIOS, it's attached to the post.
AT49F002NT@PLCC32.rar
118.09 KiB
39 downloads
Manufacturer: Award
POST String: BIOS-I-2M (91027)
Core: 10/26/1999-MVP3-586B8661-2A5LEV3KC-00
Reply 55 of 162, by Solo761
PCPartner 815EPBAS3-T217CA (also called Clayton CVAT217)
https://www.ultimateretro.net/en/motherboards/7630
Having a bit of trouble with this board, and it's unwillingness to work with my AGP cards...
But in the meantime here are some images of said board since I noticed that Ultimate Retro doesn't have one.
Reply 56 of 162, by Predator99
Saved the BIOS of 2 very destroyed boards. The 486 seems to be
Amptron DX-6900
https://www.ultimateretro.net/en/motherboards/572#downloads
The Slot-1 I didnt find.
1.07 MiB
809.75 KiB
BIOS.zip
164.87 KiB
39 downloads
Reply 57 of 162, by weedeewee
Predator99 wrote on 2022-08-11, 20:46:
Saved the BIOS of 2 very destroyed boards. The 486 seems to be Amptron DX-6900 https://www.ultimateretro.net/en/motherboards/57 […]
Amptron DX-6900
BIOS.zip
both look like pcchips mainboards to me, the amptron is already mentioned under the m912 v1.7 entry on UR, https://www.ultimateretro.net/fr/motherboards/573
There is also a patched bios to be found here on vogons for that board.
the other board, since it mentions bxcel on one of the chips makes me think it is also one of those pcchips or relabeled under a different manufacturer name, board and can likely be found in that list.
edit : https://www.ultimateretro.net/fr/motherboards/6204
Do not ask Why !
Reply 58 of 162, by creepingnet
weedeewee wrote on 2022-08-11, 21:09:
both look like pcchips mainboards to me, the amptron is already mentioned under the m912 v1.7 entry on UR, https://www.ultimater […]
Amptron DX-6900
BIOS.zip
I second on the M912 for the Socket 3. I have the exact same motherboard in my Moondog computers 486 that I got at the beginning of the year. Also, I don't think I've seen anyone use white ISA slots except PC Chips.
~The Creeping Network~
