First post, by DevilsJoker
Hello everyone
Is there anyone out there who has an Award BIOS image with the chipset code "2A4UK", or an AMI BIOS with chipset code "OP802G-H"
It is for a 486 motherboard with Opti chipset 82C822 and 82C895
Reply 1 of 9, by weedeewee
Just leaving this message here for others information, hoping that people will actually read this before replying with the same info 😉
The 82c822 seems to be for the pci support.
I checked https://www.ultimateretro.net/en/motherboards/?chipsetId=400 this list for any bios images
There were only 5 boards in the list with pci and thus the 82c822 chip and found none that had a bios image.
enjoy !
Do not ask Why !
Reply 2 of 9, by explorerdotexe
Similar to what weedeewee said, there isn't much online. Doing a search on Ultimate Retro for boards with this chipset and it's pci bridge (https://www.ultimateretro.net/en/bios/?chipsetId=666) only brings up an Award string for the Soyo SY-030E2 (07/12/94-OPTI-802G-822-2A4UKS21-00) and an AMI WinBIOS for PCPartner 802G PCI ( 40-0B02-008045-00101111-121593-OP802G-H), but no bios images.
The only rom image available for a board with the 802G chipset and it's pci bridge is for an AT&T board running IBM SurePath. (https://www.ultimateretro.net/it/motherboards/906)
Fresh off playing Pinball on the school computers.
Reply 3 of 9, by Deksor
Could you please send a good picture of your motherboard ? It may be an undocumented motherboard waiting to be documented 😀
(Or it's one of the matching board for that chipset. Nevertheless, more pictures don't hurt)
Reply 4 of 9, by darry
Deksor wrote on 2022-03-09, 17:02:
Could it be one of these Unknown Socket 3 Motherboard ?
Reply 5 of 9, by Chkcpu
I've just posted two Award -OPTI-802G-822-2A4UKS21 BIOS images on the Ultimate Retro board submission thread at
Re: Ultimate Retro board submissions thread: suggest board edits and/or add new boards here
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 7 of 9, by Horun
NSSI or Uniflash both can save a bios from DOS....
Reply 8 of 9, by Deksor
This one may be trickier, Uniflash usually supports pentium+ motherboard, and NSSI supports 64KB bioses at most, but this 486 has a 128KB bios, so it might fall right into the spot where there's no software that can dump such bios.
Now it's still worth a check, just in case uniflash manages it.
