Pentium 233MMX 66mhz sdr sweetspot.
First post, by Aebtdom
Hi everyone,
I am trying to get the maximum out of my current Pentium build and I noticed something I did not expect to give so much performance impact.
My build had 128mb pc100 sdr memory in it, running at 66mhz and it gave a decent 3dm99 score of 1287 with a single voodoo 2 card.
I ran into another bank at my parents house (apparently these things happen) and plugged it in. Yes I know it is way to much for the 233 to handle but the performance dropped to 1150, which is around a 10% loss.
My question is, what is the sweet spot? Are 2 banks slower than one? Would 2x64 be better? Or one 64mb bank? Or even 2x32mb? (PC can only allocate 2 banks of memory)
Thanks.
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 1 of 22, by Doornkaat
What mainboard do you use?
Depending on your chipset and cache config more RAM may mean less performance because it can't all be cached.
Reply 2 of 22, by Aebtdom
Of course, that's sounds reasonable
I will put a POST image in here.
Builds:
Reply 4 of 22, by Aebtdom
red-ray wrote on 2022-02-27, 13:37:
Looking at https://www.elhvb.com/mobokive/archive/intel/ … TX_67703201.pdf then only 64MB is cacheable 🙁
So, if I understand it correctly, more than 64MB is utterly useless with gaming.
So what's the smart move here? 1x64MB or 2x32MB?
Builds:
Reply 5 of 22, by Garrett W
Yes, your chipset (i430TX) is unable to cache more than 64MB RAM. If you have a single 64MB DIMM, plug that in and remove the rest and you should see a healthy boost in performance. I don't think there's any further performance to be gained by using a single stick versus two sticks.
Reply 6 of 22, by jheronimus
AFAIK there is no memory interleaving on those S7 Intel chipsets, so one stick is fine. However, if you're determined to extract maximum performance, than you should probably experiment with memory timings in your BIOS? This is where having spare sticks could be useful as different memory reacts differently.
UPD: Oh wait, you have an Intel board. Don't think they have any memory tweaking options in BIOS.
BTW, I think I've read the thing about having more than 64MB RAM hurting performance on 430FX/VX/TX chipsets a long time ago, but I still don't fully understand how it works.
Doesn't the system need to actually use more than 64MB of memory in order for it to hit non-cached regions? Or is memory allocation not that linear, and you can actually use non-cached regions with any operation?
MR BIOS catalog
Unicore catalog
Reply 7 of 22, by Aebtdom
Well if that is the case, I just ordered two 64MB PC66 CL2 memory banks and see what the system will do with it if one is plugged in.
Currently the banks I have are CL3, so I assume there would be some performance improvement.
Builds:
Reply 8 of 22, by Garrett W
Not unless you can tweak those timings in the BIOS (doubtful with an Intel or OEM board).
Reply 9 of 22, by Aebtdom
Isn't it that the mainboard autmatically takes over the CL of the memory default settings?
It is for sure not possible to tweak memory timings on this mainboard, or anything at all for that matter.
Builds:
Reply 10 of 22, by dionb
Aebtdom wrote on 2022-02-27, 13:48:
There's absolutely no advantage to be had from 2 DIMMs instead of one on a single-channel, non-interleaving memory controller. If anything the heavier load on the bus will limit clocking/timing options, although that's hardly an issue in this case as you can't tweak anything anyway.
As for the "64MB is utterly useless", consider that even uncached RAM has 1/1000 the latency of hard disk accesses, so what is ideal depends on your operating system and how much memory you are actually using:
DOS or Win9x, using less than 64MB: max 64MB perfoms best, without exceptions.
DOS or Win9x, using more than 64MB: the smallest amount of RAM that covers what you actually use performs best (i.e. if you need 75MB, go for 64+16=80MB)
WinNT/2K/XP or Linux: performance hit from uncached RAM is limited as active stuff is handled in the cached part. Probably more RAM won't hurt - but if you're using <64MB, you might as well stay under it.
Reply 11 of 22, by BitWrangler
Post-2000 using a 430TX for daily driver duties, I found going over 64MB was far preferable to the disk thrash as browsers etc continued to bloat. Keeping it light and tight, most games actually worth playing on a 430TX based system aren't gonna want more than 64.
Reply 12 of 22, by Cuttoon
jheronimus wrote on 2022-02-27, 15:25:
IIRC, Windows allocatesnot a fixed amount, but a certain percentage of RAM as HDD buffer - so if you upgrade to more, chances might increase that the actual program gets pushed to uncached area, the cached area being fixed.
Just a guess - last time it was relevant, I coundn't afford more than 64 MB of RAM.
I like jumpers.
Reply 13 of 22, by rmay635703
Add k6-3 and use as much memory as you want
Reply 14 of 22, by rasz_pl
Aebtdom wrote on 2022-02-27, 15:37:
pc100 CL3 = PC66 CL2
SDRAMs have little eprom on them with a table of minimum acceptable timings per frequency, you can see it using CPUZ (SPD tab) https://www.cpuid.com/news/66-cpu-z-vintage-edition.html
dionb wrote on 2022-02-27, 18:32:
I have this vague memory of Linux allocating ram from the top down
Reply 15 of 22, by dionb
rasz_pl wrote on 2022-02-27, 23:43:
Now I'm trying to find something concrete about it and failing, at least wrt Linux.
For Win9x it's simple: top-down, so most accessed OS functionality will be uncached. There's an interesting tool that apparently can help avoid this (by eating up all the uncached RAM right at the beginning of init, and releasing it after Windows' GUI stuff has been loaded into cached RAM), but haven't tested it yet (and particularly in case of Win95 I'm very suspicious of interfering with already very fragile OS processes):
http://www.redline.ru/~ipl/win2cache_eng.htm
WinNT is more complicated, I read reports of it filling bottom-up, but also that it's just top-down too, but that the file caching in RAM is so effective it negates the hit of OS stuff in uncached areas.
Tbh I'm beginnng to itch to test this. A nice system with i430TX and 64/128MB with DOS, Win98SE (and a second install with that win2cache) and Win2k installs (maybe some old Linux for good measure too) and then Doom/Quake/UT Timedemo.
Reply 16 of 22, by Aebtdom
Well, today I received my 64MB CL2 module and ran a test with 3dm99 max.
The result was better then I was expecting.
1x 128mb pc100 CL3 gave 1291 3dmarks and 1554 CPU
2x128mb pc100 CL3 gave 1150 3dmarks and 1507 CPU
1x64mb pc66 CL2 gave a whoppin 1369 3dmarks and 1645 CPU
The attachment Screenshot_20220301-150802_Gallery.jpg is no longer available
*edit* found cpu marks with 2x 128mb and corrected the score.
Builds:
Reply 17 of 22, by Aebtdom
I will try with an extra 64MB tomorrow, so I know if it is the 64mb module CL2 or that 128mb is just too much.
Builds:
Reply 18 of 22, by Warlord
sweet spot would be run it at 100mhz FSB instead of 66mhz. The CPU will run at 250mhz. Your board looks like it can't do that though.
Reply 19 of 22, by Aebtdom
I know, that's why I used 66mhz in the title. And 100mhz isn't exactly where the chip was designed for 😉
Builds:
