First post, by TOMMY_THE_DOG
Hello everyone. I have a Compaq 5184 mini-tower with a SS7 motherboard and a K6-2 CPU. The system shipped with a 380MHz CPU, which I decided to upgrade to a 533MHz. Both regular K6-2s with the same rated voltages. The faster CPU went into the socket just fine, and the system boots and runs well. But the new CPU was running at the same 380MHz as the stock CPU! As reported by the BIOS and CPU-Z. The BIOS will not allow me to change the multipliers, but I found some spotty documentation that showed me where the jumpers are on the motherboard for changing CPU and FSB multipliers. I was able to bump the FSB up to 100MHz, which brought the CPU to an even 400MHz speed. Somehow this modest speed increase was quite noticeable in Win98SE. But it is still far below this processor's rated speed. The system runs very stable at this configuration.
The documentation only mentions clock multipliers up to 4x for the CPU. The jumpers on the motherboard were already set to that. I experimented with all of the different combinations of jumper positions, but the only other one that POSTed was the setting that brought the CPU to 266 MHz.
Is there any way to set the CPU multiplier in software? What program would I need? Is there any work around at all? A new BIOS to flash? This is a SiS530 chipset. I know that it is not a highly regarded chipset, but I am very happy with this system for the most part. I just want it to be a bit faster.
Reply 1 of 48, by Cuttoon
set the multiplier to 2x, the chip should interpret that as 6x. They were built that way to tackle the problem of multiplier limitations.
Of course, that would mean 600 MHz with 100 FSB, so it might not run stable - reduce to 75 MHz FSB for 450 MHz or something in between, if available.
Or try increasing the core voltage, at your own risk.
In any case you should try to get a real manual for the motherboard, if at all obtainable. Some Compaq enthusiasts here will help you out.
There actually is a method to set the multiplier via software for K6-2+ and K6-III+ chips, called setmul.
SetMul - Multiplier control for VIA C3 / AMD K6+7+8 Mobile / Cyrix 5x86
Those chips are just not quite as easy to download 😉
I like jumpers.
Reply 2 of 48, by debs3759
533 is 97 x 5.5, so set the fsb to 97 and multiplier to (I think) 1.5 (for 5.5)
Reply 3 of 48, by TOMMY_THE_DOG
Unfortunately, the manual only has jumper settings listed for 3x, 3.5x, and 4x. Does setmul only work on 'plus' model CPUs? Thank you for your responses. Here is the information that I have at hand from a PDF manual:
    52.12 KiB
Reply 4 of 48, by debs3759
Have you tried undocumented jumper combinations for the multiplier? Some should work.
Hopefully someone who knows the chipset can tell you more for certain.
Reply 5 of 48, by Doornkaat
From the table we can extrapolate that J14=BF1 and that 1-2=BF signal high (corresponding jumper open on most motherboards) /2-3=BF signal low (corresponding jumper closed on most motherboards).
As soon as we know all three BF jumpers we can set any multiplier supported by the K6-2.
To figure out the other two BF jumpers please set the jumpers as follows:
Multiplier: J14 2-3 / J15 2-3 / J16 1-2.
FSB: J8 2-3 / J9 2-3 / J10 1-2 / J11 1-2 / J12 1-2. (100MHz)
If it posts at 250MHz we know J15=BF0 and J16=BF2.
If it posts at 500MHz we know J16=BF0 and J15=BF2.
If it does something else my conclusions are probably wrong. 😄
Reply 6 of 48, by Sphere478
Cuttoon wrote on 2022-03-12, 01:46:
set the multiplier to 2x, the chip should interpret that as 6x. They were built that way to tackle the problem of multiplier lim […]
A k62 isn’t going to be happy at 6x 100fsb.
Question to OP
We need a good pic of your motherboard can you pull it and take a front and back pic?
https://www.ultimateretro.net/en/
Or find it here (but be sure it’s exactly the same because if you are wrong out help will be misguided.)
Basically I’ve seen many threads like this and it’s all hopeless without starting with a good awareness of EXACTLY the mobo we are helping with.
Sphere's PCB projects.
Reply 7 of 48, by Sphere478
I’m gonna make a guess here:
J14 appears to be Bf1
2-3 is on 1-2 is off
5.5x is either
J14off j15off j16 on
J14off j15 on j16 off
Typically there is no harm in trying combinations of 1-2 or 2-3 just don’t do 1-1 or 1-3 or anything weird like that.
Edit, I see someone else beat me to it, looks like I should finish reading the thread before replying 🤣. Though I concluded 2-3 as on/closed
In any case looks like we both suggested the same two settings to try.
Reply 8 of 48, by Sphere478
Another thing, but maybe something for later, you can probably get a k6-3+ running in this at 600 mhz which will be a significant improvement over even the k6-2 533 with its l2 cache that the + cpus bring
See my signature about 2+ To 3+ Mod
Which brings us back around to your OP question
These + cpus do actually support software multiplier switching from windows.
Reply 9 of 48, by Shreddoc
TOMMY_THE_DOG wrote on 2022-03-12, 02:40:
Correct. You need a + model of K6/2 in order to change multipliers using setmul.
However, the K6/2 CPU will support motherboard jumper settings that are not documented in the motherboard manual, in order to achieve the CPU Mhz you want. It is a common setup scenario faced when dealing with K6/2 systems.
Reply 10 of 48, by Doornkaat
Sphere478 wrote on 2022-03-12, 07:06:
I did as well. A closed BF jumper usually means the signal gets pulled low by the motherboard. That's why a closed BF jumper ('on' as in 'jumper on pins') gives a logical signal of 0 while leaving the jumper off will result in a logical 1 on K6 CPUs because of internal pullups. Jumper 'on' means signal 'off'. It's very counterintuitive.😄
Reply 11 of 48, by Sphere478
Doornkaat wrote on 2022-03-12, 08:23:
Makes sense actually. Thx for the clarification.
Reply 12 of 48, by Doornkaat
Sphere478 wrote on 2022-03-12, 09:03:
I have this table with multiplier settings for various S7 CPUs that operates with 1 (signal high/no jumper) and 0 (signal low/jumper set) and it every time I use it it takes me a minute to wrap my head around it again.😂
Reply 13 of 48, by TOMMY_THE_DOG
Doornkaat wrote on 2022-03-12, 06:22:
From the table we can extrapolate that J14=BF1 and that 1-2=BF signal high (corresponding jumper open on most motherboards) /2-3 […]
That got it to 550MHz! Woohoo! Mission accomplished! Thank you so much everyone.
I got this CPU for $12, so it is a good upgrade! I know that the plus models are a bit better, but for a system with no AGP slot, I don't think the upgrade would be worth it for me in this machine. Thank you again.
I imagine that a CPU nominally rated at 533MHz will be fine at 550. My FSB is still at 100MHz.
Reply 15 of 48, by TOMMY_THE_DOG
Oh man, Redneck Rampage just posted a Dos4GW error and crashed. That's never happened before. Jazz Jackrabbit is giving the runtime 200 error. Is there anything wrong with just patching it like I did for my Coppermine machine? The game worked fine at 400MHz on the K6-2. Maybe I will pick up a 2+ eventually for that software multiplier. It would be nice to be able to bring the system down for compatibility. It's not in the budget right now, though.
All that said, Duke Nukem 3D is performing like a champ, and it is a better game than RR anyway. I just like RR as a benchmark.
Reply 16 of 48, by TOMMY_THE_DOG
Doornkaat wrote on 2022-03-12, 16:56:
Congrats! 😃👍
Will you let us know what jumper config got you to 550MHz?
The one that you thought would take it to 500MHz:
Reply 17 of 48, by Doornkaat
Huh, that either contradicts the manual or there's stuff going on that I don't know about.
I had been wondering why they would put the jumpers in another order than BF0, BF1, BF2. Seems like that's the order they're in after all.👌
Reply 18 of 48, by Sphere478
TOMMY_THE_DOG wrote on 2022-03-12, 16:49:
That got it to 550MHz! Woohoo! Mission accomplished! Thank you so much everyone. I got this CPU for $12, so it is a good upgr […]
What cpu is it? What are the letters of the model? Example “k6-2+ 570acz”
Yeah, 550 is probably fine for a 533
Do stability testing to confirm it’s stable, may need a 0.1v bump
Speaking of, you should check your voltage
A resistor leg in the middle pin on the notched corner side of the cpu to ground with a volt meter is the easiest way to test. Close the lever.
18.52 KiB
Btw, what setting did you use? What mobo is it? We could document it on ultimate retro if you can provide more infos
Edit: reading further,
Try the next fsb setting (95mhz if you have it) but before you do that, confirm voltage the 550 uses .1v more than the 533
    1.76 MiB
Reply 19 of 48, by Shreddoc
TOMMY_THE_DOG wrote on 2022-03-12, 16:59:
Setting up physical switches is another option; it's what I did for my K6/2. So you can flick a couple of switches before turning on, to set various speeds between 166 and 500Mhz. Then on top of that, setmul can be used to disable L1 cache. Overall it covers quite a range.
