Reply 60 of 63, by Radical Vision
- Oldbie
Well i can give u some cheaper ideas what to look for..
The best and cheap option will be this ECS board
ECS P6IPAT (V1.0) it supports up to 1.3GHz Tualatin, and last time when i did check did cost like 30-40 euros..
Other way is modification on this SLOTket adapter, will make it to support Tualatin CPUs, so you can use them on most Slot 1 boards that support at least 700-800MHz coppermine..
MSI MS-6905 Master
Another way is if you find somewhere this Lin-Lin Converter slocket it support tualatins... With this i was able to run 1.3Ghz Tualatin on that MSI 6905 adapter non modded on ABIT BE6... But i think this Lin-Lin is rare, and prob very expensive similar to Power Leap ones...
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
