First post, by Sphere478
I’ve pretty well explored most of the fastest amd and nvidia pci options for my k6-3+ builds but what’s the fastest for matrox? Did they ever make anything faster than a ATI 7500? Being as the 7500 is my best card for these builds I’m wondering if there may be something better than it from matrox.
Sphere's PCB projects.
Reply 1 of 8, by darry
Sphere478 wrote on 2022-05-17, 04:38:
Fastest in what regard ?
DOS (VGA) performance ?
Direct3D or OpenGL acceleration ?
AFAICR, their last PCI (not PCI Express) solutions were the G450/G550 variants . The 3D performance is in the same ballpark as a Geforce2 MX200 according to http://ixbtlabs.com/articles/g550/index.html. And a Geforce 2 MX200 is no match for a Radeon 7500, at least in this benchmark https://www.anandtech.com/show/872/6 .
Reply 2 of 8, by luckybob
The reason to get matrox is vga (analog) video quality. Once you are past the g200/g250 the only reason to use matrox is multi-monitor.
also "fastest" card changes with EVERY game. It hardly matters, imho. Get something reliable with good compatibility is my advice.
Reply 3 of 8, by TrashPanda
darry wrote on 2022-05-17, 04:57:
Fastest in what regard ? […]
I have a pci-x parhelia which will work just fine in a pci slot, pretty sure it would be faster than the g550.
That said the 450max was faster than the 550.
Oh noes, the cap let the shmooo out 😁
Reply 4 of 8, by Sphere478
TrashPanda wrote on 2022-05-17, 05:10:
have you ever stuck that in a 430hx mobo? if not, could you? I'd be very curious to know if it would work in my tyan s1564
Reply 5 of 8, by TrashPanda
Sphere478 wrote on 2022-05-17, 05:12:
I would have to check what boards I have, not sure I have a 430hx but I’m sure I could find something close.
Reply 6 of 8, by Sphere478
Sweet!
Reply 7 of 8, by dr.zeissler
I also have a PCI-x Parhelia, but this card only works on Win2k+ so no retro-usage for me...
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 8 of 8, by The Serpent Rider
G450 PCI was the last PCI card from Matrox for normies. G550 PCI don't have normal DVI or VGA.
They are all more or less identical in that regard after G200.
