First post, by Peter.Mengel
Hi what Motherboard Driver do i need, i dont see any kind of what motherboard this is? Anyone has Drivers for that PC? Thanks alot.
Win98/95 ones would be Perfect 😀
Reply 1 of 19, by mustagcoupe
You are likely going to have to track down drivers manually. I have an aptiva 2153 that came with a k6-2 on an ali aladin v chipset motherboard. I was able to identify some of the drivers i needed by reading chips on the board. Some of the devices had to be identified in device manager to find out what it was so i could track down drivers. And some of the drivers and some good information i found on this page (https://aptivasupport.com/aptiva.html)
Reply 2 of 19, by Horun
Hmm at the old IBM archive is lists 2151 but only 82C, 84P, 84Q, 84V, 88P, 88Q and 88R. No 30A.
and links are broken.....
Reply 3 of 19, by mustagcoupe
Horun wrote on 2022-06-12, 21:25:
The 30a might be basically the same and just a code signifying what store it was meant to be sold at or something. And sometimes you can put broken links in the wayback machine. If its archived the downloads usually still work to.
Reply 4 of 19, by mustagcoupe
I did some more research and unfortunately the wayback machine did not save any of the drivers. It appears that machine was offered in both a pentium 2 version with presumably an intel chipset and a k6-2 version. If the k6-2 version is anything like the aptiva 2153 it probably has an ali aladin v chipset. Video is probably either a riva tnt2 or an ati rage of some kind. Without further information on what parts this machine contains i cannot track down any drivers.
Reply 5 of 19, by Horun
Yes need more info: chipset, cpu type, etc. I also saw that one with a 2151 -88P claimed it was a Slot 1 Pentium 2. A quick Archive search got me here:
http://web.archive.org/web/200006151810 ... iva%7c2151
but hit road blocks after that....
if you can get the driver numbers they may be here: http://ps-2.kev009.com/pccbbs/aptiva/
BUT there is no 2151 models files listed. There is manuals/files for 2136, 2137, 2138, 2139, 2140, 2142, 2144, 2153, 2156, 2159, 2163, 2168, and more ;p but no 2151 🙁
side note: In my archive collection is this for NetVista series: http://web.archive.org/web/20020802230910/htt … IGR-4MVU6P.html
If the link does not open then: copy the shortcut and shorten to just the web page .html you can open most of them and get the bios, driver, etc names.
example for my Netvista M42 8307: http://web.archive.org/web/20020802230910/htt … pe=&subtype=Cat
becomes http://web.archive.org/web/20021105125617/htt … MIGR-42954.html 😀
I have not found a way to get to the Aptiva MIGR-***** html's yet 🙁
Reply 7 of 19, by Horun
Great find ! and explains why so little information is out there for that model......
There is nothing at http://ps-2.kev009.com/pccbbs/ about any 2151 model...
Reply 8 of 19, by PC Hoarder Patrol
Horun wrote on 2022-06-14, 23:26:
It is there, but I ignored lt on first pass as it didn't mention the 30A - http://ps-2.kev009.com/pcpartnerinfo/ctstips/d1ae.htm - then I couldn't find it again with a later search but stumbled on the archived IBM link instead.
Reply 10 of 19, by mustagcoupe
Peter.Mengel wrote on 2022-06-16, 00:09:
Funny to say but windows 98 did dilever all the driver needed. Seems like its out of the box working! I had no problems yet. Thanks anyway for all the help 😀
Can you please make a post listing what hardware this machine has so that anyone who has this issue in the future and doesn't want to use windows 98 can track down drivers for it.
Reply 11 of 19, by Horun
mustagcoupe wrote on 2022-06-16, 00:37:
Yes ^^ great idea !
Some pictures of the motherboard would be great too 😀
Reply 12 of 19, by Peter.Mengel
Horun wrote on 2022-06-16, 01:59:
Yes ^^ great idea !
Its a Acer V58XA Board
Video Chipset: ATi 3D Rage II/II+ (264GT) (2MB max VRAM)
Audio Chipset: Crystal CS4237 (CS4237)
Chipset:ALi M1531/33/43 (Aladdin IV & IV+) [M1531, M1533, M1543/M1543C]
Reply 13 of 19, by Horun
Thanks ! Never thought an Acer board would be in an IBM of that era computer but then based on the https://web.archive.org/web/20040816004613/ht … cid=DETR-3ZWS8S
They were resellers/system configurers so could have put any board in any machine and just changed the sub code if a IBM model since they were responsible for tech support....
For driver and docs refer you here: https://www.ultimateretro.net/en/motherboards/6910#downloads and http://www.uktsupport.co.uk/acer/mb/v58xa.htm
and maybe this: https://www.elhvb.com/supportbios.info/archiv … cer/v58xasg.pdf
PC Hoarder Patrol wrote on 2022-06-15, 04:23:
I looked over dozen of pages but missed that one 🙁 Good work !
Reply 14 of 19, by PC Hoarder Patrol
Horun wrote on 2022-06-18, 02:07:
Thanks ! Never thought an Acer board would be in an IBM of that era computer but then based on the https://web.archive.org/web/2 […]
Not just the 2151 it seems - wonder how many other models / non-IBM board options existed?
http://ps-2.kev009.com/pcpartnerinfo/ctstips/31fe.htm
http://ps-2.kev009.com/pcpartnerinfo/ctstips/29e6.htm
Reply 15 of 19, by Horun
PC Hoarder Patrol wrote on 2022-06-18, 03:20:
Interesting !! I did find the orig IBM page for the jumpers for the board part no. 12J6890 and it does list as 2137 E series, hard to read but the FRU on OP board could be 12j6890 or 8890 ??
the jumpers seem to match.. http://web.archive.org/web/20030225134056/htt … MYS-3LLS5T.html
and at bottom does list XXA for possible 30A which could apply to the 2151 also.
http://ps-2.kev009.com/pcpartnerinfo/ctstips/5a1a.htm
Also found these about the BIOS: http://ps-2.kev009.com/pcpartnerinfo/ctstips/c3ba.htm and http://ps-2.kev009.com/pcpartnerinfo/ctstips/50a6.htm
For drivers it gets a bit weird, many thru google searchs for same boards drivers going back to 2005 and before show they found nearly nothing.
Reply 16 of 19, by Peter.Mengel
PC Hoarder Patrol wrote on 2022-06-14, 11:03:
OP doesn't mention a location, so might be relevant - https://web.archive.org/web/20040816004613/ht … cid=DETR-3ZWS8S
Germany so yeah it fits into the Discription.
Reply 17 of 19, by Horun
For Win95/98 drivers you need the ALI IDE driver and the ATI 3D Rage II+ driver:
https://vintage3d.org/driver/ati/Rage%20II%20w82420en.exe
    aliide_v3.40.zip
    786.71 KiB
    28 downloads
Reply 18 of 19, by Peter.Mengel
Horun wrote on 2022-06-18, 20:18:
Is it worth it? Cause basic win98 Drivers work out of the box? Any Performance/Stability Boost?
Reply 19 of 19, by Horun
Think those drivers are designed to work in Win95 and 95 OSR2 as well as Win98 but since 98 has drivers you probably would not gain anything. Does the IDE controller show as Buss Master or DMA mode ?
They do supply Bus mastering DMA under Win95 otherwise would be just standard IDE PIO mode, which is slower
