First post, by Saidian
I have been wondering past few days if the system I'm building would be better served with having 98 or XP as the OS.
I still have a bunch of parts to get but I've nailed down the main 4:
Pentium iii 1ghz Coppermine
DFI CS61-EC Motherboard
512 PC133 SDRAM (Max the above supports)
Nvidia Geforce 4 Ti4200
Sound Blaster Live SB0220
I do have a few older pre 1995 DOS games I want to play but considering I can use Dosbox for those (right?) I'm wondering if XP would be a better fit than 98 considering the majority of my library playing games up to Freelancer, KOTOR and possibly World of Warcraft Vanilla. Will be running a good amount of console emulation too.
Will the higher requirements of XP have a negative impact or will it not really matter?
Reply 2 of 51, by Jura Tastatura
That's an excellent W98 machine (or shitty XP rig, your choice). For ultimate XP gaming I personally woldn't go bellow Core2Duo and something like GTX280.
Reply 3 of 51, by kitten.may.cry
jheronimus wrote on 2022-06-11, 12:20:
Win2K is actually a good option, too. Supports a lot of the same stuff as XP, but lighter and smaller.
At least you didn't tell him to use WinME.
Reply 5 of 51, by Saidian
kitten.may.cry wrote on 2022-06-11, 12:22:
I remember seeing as a kid Windows ME on store shelves when it launched and thought "WOW SO COOL!" 🤣
What do you think, would Win2k be a better fit?
Reply 6 of 51, by Saidian
DosFreak wrote on 2022-06-11, 12:24:
Why not both?
I'll still get speed issues on DOS no matter what with my CPU right? Would there be any difference using Dosbox in 2000 vs 98?
Can you tell I'm extremely new to working with Dos on older hardware? 🤣
Reply 8 of 51, by cyclone3d
Use Windows 98SE with NUSB and the 2004 Microsoft update CD available on vogonsdrivers.
DO NOT use the unofficial SP3 as it causes way too many problems because it includes files from newer versions of Windows and just screws stuff up.
That system will be fine for DOS games that are not CPU sensitive. However you will want a sound card that actually supports DOS properly.
DOSBox is not going to be quick enough with that system IMO.
It will also make a really sucky XP machine.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 51, by leonardo
Saidian wrote on 2022-06-11, 11:48:
I have been wondering past few days if the system I'm building would be better served with having 98 or XP as the OS. […]
Windows 95 OSR2 (skip 98 if you don't need DirectX 9.0). 😎
edit: The above with the caveat that there are some titles that you mention that are right on the cusp of if they'll be usable or not. I found out that WarCraft III (and by extension WoW) require DX 8.1 and thus are just out of reach on Windows 95, even though a PIII 1 GHz is a beast of a 95-machine otherwise.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 10 of 51, by Shponglefan
Based on the specs you list, I would go with Windows 98SE especially if the intent is to run DOS games.
Though I would also use a different sound card like an ESS Solo-1 or Aureal Vortex 2-based card. That's just my preference.
For XP, you'll want a beefier system.
386 DX-40 multi-audio build
Tandy 1000 TL restoration
Ultimate Windows XP build
Reply 11 of 51, by framebuffer
I see no point to use Win98 with a Ti 4200 and early 2000 games
Anyhow keep in mind that you are pairing a CPU from 2000 with a VGA from 2002, so you'll not get the most out of it
Windows 98 and SAMBA | Quake CPU Benchmarks | GeForce2: GTS vs MX400
Reply 12 of 51, by framebuffer
Shponglefan wrote on 2022-06-11, 16:02:
XP was introduced in late 2001 and was used/popular until the introduction of Windows 7 in late 2009.
In my opinion there is not only one XP era but it can be split at least in 3, and for the first part, although the Coppermine 1GHz is a little on the weak side, he's system is gonna be fine
Reply 13 of 51, by Baoran
Jura Tastatura wrote on 2022-06-11, 12:21:
I think windows xp works fine in that. Not everything has to be "ultimate" or whatever that means.
I think it would be better to choose the OS based on what you want to do with the computer. For KOTOR and freelancer windows xp would be better.
Reply 14 of 51, by Shponglefan
framebuffer wrote on 2022-06-11, 16:32:
True, there is a wide time period which covers the XP era. It ultimately comes down to individual goals.
Reply 15 of 51, by Saidian
Long as I can run the games I listed in Win98SE I guess I'll go with that then.
All I'm focused on is getting the best performance with the hardware I'll have, don't want to install XP if it's just gonna bring down the overall performance.
Reply 16 of 51, by RandomStranger
I don't know, the SB0220 is a good sound card with EAX support, which you probably want in a W98 system. Also decent in DOS.
The Vortex 2 has A3D which is also desirable (though I think much more niche).
As for the Solo-1, it is a great sound card, but how much do you gain in DOS compatiblity without the mainboard having SBLINK connector (at least I think this one does lack that) that it's worth losing native EAX and/or A3D?
Reply 17 of 51, by BinaryDemon
Don’t get me wrong, 2001-era-Me would have been rushing to install XP but 2022-era-Me would stick with Win98.
Or have multiple OS. Win98, XP, and some lightweight Linux distro.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 18 of 51, by Saidian
Yeh I don't really want to dual boot useless it was 100% necessary
Btw guys I should probably mention other than the RAM and GPU I either already have the main components on hand or they've been shipped and are on the way to me.
Reply 19 of 51, by Shponglefan
RandomStranger wrote on 2022-06-11, 17:03:
It comes down to preference. In my own experience, I prize A3D support above early EAX support; I find 3D sound via A3D to be a superior experience than early EAX. And for DOS gaming specifically, I like having an internal wavetable header to use wavetable cards for MIDI music.
In my current Win98 build I use a Diamond MX300 which yields A3D 2.0, EAX 1.0, and wavetable MIDI support via a Yucatan FX wavetable card.
Ultimately it comes down to preferences/priorities and which games people prefer to play.
