First post, by Saidian
Someone I know gave me a Fujitsu E5710 system and besides needing a clean it appears to be running smoothly.
I notice the 250w PSU isn't a standard design so my options are a bit limited. I'm wondering what would be the best low profile GPU I could safely throw in?
It looks like 300w units of the same form factor are available but of course that's an added cost so I'd rather not.
Specs of Machine as it stands
Pentium D 2.8ghz (any chance I could replace with a e8500?)
2gb DDR2 (had 3gb but the 1gb second stick isn't showing up so I'm assuming it's dead)
80gb Seagate Baracuda SATA Drive
DVD-RW Drive. Came with a Lightscribe drive but it appears to be damaged, won't boot any disc and said discs are still spinning upon ejection (I'll just replace it)
Floppy Drive
I plan on replacing the CPU (if the E8500 is compatible), RAM (bump it to 4gb), fans, and DVD-RW Drive.
