Reply 20 of 22, by paradigital
- Oldbie
NyLan wrote on 2022-06-25, 22:26:soldering caps is ok, SMD can be tricky at some point
Soldering SMD isn’t too difficult, either with hot air or the slide-in method with a decent iron. Biggest issue with hot air is protecting heat sensitive stuff around the area (like the slots).
I’m not likely to be recapping mine, I only bought the PC for the case, I don’t want or need the internals!
