Not boot
First post, by rain
Hi, i have old socket 7 motherboard, when trying from boot from floppy its not working with windows 98 boot disk? its working a little bit then stopping from boot
Reply 1 of 19, by Meatball
rain wrote on 2022-07-21, 15:00:
Disconnect the Hard disk and all other IDE devices, and then try again. My experience has been there's something going on with the disk when this happens, though. If it is disk related, you can then start examining the BIOS settings, partition layout, etc.
***->WINNER, 1ST PLACE<-***
2022 #QUAKE3totheMAX -560.5fps-
Brain Drain Retro LAN https://discord.com/channels/799008837918261328
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
DDR@411MHz (2-3-3-3)
GeForce 256 DDR@144/344MHz
ESS Maestr0-1
Reply 2 of 19, by Sphere478
Some of the bios settings may be to blame.
Sometimes system bios cachable. And various other settings as well.
What board?
What processor?
What ram?
What ram config?
What cards?
Sphere's PCB projects.
Reply 5 of 19, by rain
Sphere478 wrote on 2022-07-21, 23:27:
Some of the bios settings may be to blame. […]
What board?
What processor?
What ram?
What ram config?
What cards?
how to disable cache?
Reply 7 of 19, by zapbuzz
Make sure your hard disks drive selection jumper is primary/master and if you have a cdrom it is set to secondary/slave (I do not condone slavery some disks have that printed on it however)
Your hard disk it could be too big I wonder if your bios can view the correct capacity in the menu if not you'll need a dynamic drive overlay to access it or a modded bios update (wims bios forum can help).
Reply 8 of 19, by rain
zapbuzz wrote on 2022-07-22, 13:49:
i tried only floppy disk is attached still not working
Reply 9 of 19, by zapbuzz
rain wrote on 2022-07-22, 14:04:
that can mean the memory is faulty and I would try one module at a time to find it or remove one at a time to find it
Reply 11 of 19, by zapbuzz
rain wrote on 2022-07-22, 15:37:
tried one module but this time mobo not even opening
then it requires a pair to run but im pretty sure you can set the bios to slow boot or look for memory checking so it scans memory several times
Reply 12 of 19, by Sphere478
Try playing with bios settings. Sometimes they will cause behaviors like this.
All socket 5/7 mobos require pairs of 72 pin simms. Or a single dimm
rain wrote on 2022-07-22, 06:17:
motherboard: dfi G586IPV REV : C RAM : 2X8 MB SİEMENS EDO RAM CPU : PENTIUM 120 maxtor 20 gb hdd […]
CPU : PENTIUM 120
maxtor 20 gb hdd
https://www.ultimateretro.net/en/motherboards/1766
Possible bios update btw:
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
110.54 KiB
This model is close… may wanna ask chkcpu (user here) if it’s the right one. That user is Jan from the site. This thread is a good place to talk to him.
Re: Diy modding support for k6+And 120gb hard drives into bios roms
Reply 14 of 19, by Sphere478
I’ve had such bad luck with floppies that I got a gotek with oled, dial encoder and flash floppy. And don’t even use floppies anymore
Reply 15 of 19, by rain
Sphere478 wrote on 2022-07-22, 17:42:
do you know about anything about system bios caching?
Reply 16 of 19, by Sphere478
rain wrote on 2022-07-23, 06:35:
Sometimes it can cause issues. Try and find out.
Reply 17 of 19, by rain
Sphere478 wrote on 2022-07-23, 16:31:
how to do it? which part of bios screen?
