That appears to be a standard ceramic disk capacitor, they almost never get damaged. Also there is lots of corrosion (and some green) around that cap and resistors. I suspect bad solder joints and corroded via's.
Most likely the cap in a 0.o1uF based on it's size but am probably wrong....I would guess it same size as the one near the PSU connector...(from a different picture)
