First post, by Bernkastel7734
Hello,
I have been using PC Chips M726 motherboard as my test one ( for testing graphics cards and so on) it was working with no problems. I have left it in my workshop after testing new monitor ( motherboard was used as a signal source for the monitor, I was using one of these MDA/LPT card) and the next day when I had time to come back to finish testing, that motherboard just stopped working. I have tried to use ISA POST card but it just shows no activity ( displays -- -- ) like that motherboard was dead. Any idea what's going on? What is more, this is a second motherboard this week that I was using as a test one and just died the other day.
I have checked voltages for BIOS eeprom, RAM and CPU ( Celeron 333) and they all look fine, also there is no bulged capacitors.
https://www.ultimateretro.net/en/motherboards/4169
Reply 1 of 1, by Sphere478
Pull it all apart and put it back together ram cards etc.
Then try the parts in other mobos.
Check for metal shavings/solder blobs
Sphere's PCB projects.
