First post, by lalakobe
Hello all!
I have in posession Investronica M TUB-002 8086 motherboard (https://theretroweb.com/motherboards/s/invest … onica-m-tub-002) which is 8 MHz one. It has two oscillators on board, one 14 Mhz, the other 48 Mhz. I think that 48 one is divided by 2, and then by 3, giving 8 Mhz bus speed.
I want to replace 48 Mhz oscillator with 60 Mhz in order to run 10 MHz CPU (NEC V30 or Intel D8086-1) at full speed. There are 5V and 3.3V ones in local store, I guess I need 5V one?
