First post, by LordWaldemar
I was rebuilding a S7 system and often found answers to my questions in this forum so I registered myself to get answers I couldn't find on the Internet.
I'm currently running a K6-IIIE+ 400MHz on a DFI K6BV3+, sadly Rev A1 so no voltage below 2V. The CPU is rated for 1.6V, overclocked to 550MHz and cooled by a Socket A cooler I scavenged from a 1.6GHz Sempron, if Everest is right at about 37°C. Everest also tells me the VCore is about 2.5V but I've read it always shows this in this board no matter what is set. However it is set to 2V and I've ran this system only for short durations. Is it safe for longer or do I risk to fry the CPU?
Should I play it safe, get a CPU that's comfortable with 2V and try to get another board that supports 1.6V? I've also seen adaptors to upgrade older S7 boards but no idea where to get one in germany.
Thanks in advance!
best regards
'99: K6-3 400, DFI K6BV3+, 1024K+128M PC100, GeForce 2 MX400 32MB, 98SE
'03: Athlon XP 2500+, Asus A7N8X, 512MB DDR400, Radeon 9600XT 256MB, XP
'06: Athlon 64 X2 3800+, DFI Lanparty UT nF4 Ultra D, 2GB DDR400, Radeon X1800XT 512MB, XP/7
Reply 2 of 11, by majestyk
The 550 MHz K6-3+ Low Voltage was rated for 1.8V, so this would be the reference here. At 2V it´s overvolted by 11%.
This is no tragedy, but the Low Voltage edition was designed / selected for extremely energy efficient and cool operation. I think it´s a pity to have it operate at the voltage of the regular K6-3+.
Why not get a Mobo that can provide 1.8V or mod the regulator of the K6BVIII+ and use a smaller cooler?
Reply 3 of 11, by LordWaldemar
Thanks for the input!
Sadly hardware from that era, especially later Socket 7 boards that support below 2V seem really hard to come by, at least for reasonable prices (reasonable for me is around 20€ for a board).
Modding the board sounds interesting, I've already seen it has a jumper, that's not populated with pins, that should allow lower voltages but I'm afraid to break it and then I don't have a board for this CPU at all 🙁
Another thought is, I dont know how much lower I could go for 550MHz anyway, so it's a bit of a gamble. At the moment the board runs its highest possible clock setting with the lowest possible voltage.
best regards
Reply 4 of 11, by brian105
majestyk wrote on 2022-08-28, 19:55:
This seems like a lot of effort for what is effectively an underclocked K6-3+. Embedded motherboards are hard to come by, especially in working condition, and they may not include niceties like AGP or USB. I think that most K6-3+'s could work at this voltage and clock speed, but they weren't tested for this configuration outside of this specific SKU.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 5 of 11, by Chkcpu
Hi LordWaldemar,
These (ultra) low power 1.6V - 1.8V versions of the K6plus were designed for embedded fan-less applications, and in my experience it is completely safe to run them at 2.0V Vcore.
I believe that these low voltage versions use the same 0.18 micron die as the faster 2.0V models and were just binned to run stable and cool at these lower voltages. However when run at 2.0V, they will behave like other K6plus 2.0V versions and will need a cooler/fan, but they will also run faster then.
Running your 1.6V K6-IIIE+/400 at 2.0V and 550MHz at 37C is great! Just enjoy this nice ss7 build. 😉
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 6 of 11, by Sphere478
You need a pretty large passive heatsink to get a k6-3+ running without getting crazy hot (or just a little air flow from a case/psu fan over a passive sink)
They are pretty cool chips at 400/1.6v though
The coolest socket 7 chip I have played with is probably the tillamook. It is on a whole other level. I’ve ran those for extended periods underclocked and under volted with NO heat sink. Lol
Anyway, that chip and the other 3+/2+ cpus are basically all the same thing. Amd set them up differently to make the different models. Some will have better overclocks than others. But they are all the same core. The higher binned 2+ chips usually unlock to 3+ like the 570, 550 but the lower speed binned ones it’s a crap shoot.
Here has been my experience with voltage on these chips:
Consider 1.6v undervolted for lower tdp you don’t want to go much lower than this. Doing good to get above 500 at this level.
1.8v you may have issues above 500mhz, 600 is possible
Consider 2.0v stock voltage usually good for 600mhz most chips
Consider 2.2v upper end of normal voltage decent chance of 630 with many chips.
Consider 2.4v overclocking upper limit. (Be careful) 600-690 is possible
2.0v on this chip is totally acceptable despite the label and is no cause for consern.
If you want to lower the voltage or check it,
Re: Socket 5/7/SS7 (Voltage Interposer) Tweaker. (Beta)
Interposer^
Read voltage>
Read the voltage to ground of the middle outer notch pin on the cpu socket with a resistor leg in it
Btw, set that cpu at 2x setting on mobo for a fun surprise 😀
Sphere's PCB projects.
Reply 7 of 11, by LordWaldemar
I set it to 2x and it didn't post, it was a surprise but not a fun one 😅
That interposer looks like it's a little over my abilities but thanks I will try it maybe some time in the future.
best regards
Reply 8 of 11, by Repo Man11
LordWaldemar wrote on 2022-08-29, 17:43:
Not the intended surprise...
Reminds me of this joke by Jack Handey: "One year Dad decided he was going to take us on a "surprise vacation." We wouldn't know where we were until we got there. We were all real excited when we piled into the station wagon early one morning. We went about five blocks, then we got in an accident at a four-way stop.
I guess it was a pretty good surprise, but why did we need all that camping gear?"
Reply 9 of 11, by Sphere478
Bummer. Try 2.1v and 95 fsb
2x = 6x on that cpu
Repo Man11 wrote on 2022-08-29, 17:48:
Not the intended surprise... […]
Haha
Reply 10 of 11, by LordWaldemar
Maybe I'll try 2.1V but 95x6 would just be another 20MHz with slower RAM (don't know if RAM speed even really matters on the system), that doesn't seem like a good idea to me 😅
best regards
Reply 11 of 11, by Sphere478
There really should be no issue at all running that at 2.1.
Yeah, 95 may hurt more than 570 helps.
