First post, by kenan83
Hello. I have a yedata yd 380B 5.25 1.2mb floppy drive. I couldn't read my floppy disks. I am formatting the omnidisk, but. When I want to switch to A, it says the floppy disk cannot be read. I don't know what I'm doing wrong. Should I format the omnidisk as fm or mfm? I will be glad if you help. I am sharing the image after the format on the omnidisk. I don't know if it was formatted.By the way, I also cleaned the lens of the disk. As a jumper, jumper 0 on a single cable. c de a: it can't read the disk when I do enter.
