First post, by Shponglefan
- l33t
Try airing it outside for a few days or longer as needed.
Last time I had electronics that had a heavy smoker smell, a week outside cleared up the smell.
clean them good with isopropyl alcohol. then get some of those scented sheets u can put in the dryer. sandwich the cable in between some and seal them into a zip lock bag for a couple days.
when u take them out they should just smell like the scent of the dryer sheets after a couple days that smell also should go away and they should just smell normal.
if that don't get rid of the smell then not much u can do after that.
Windex on a rag works well to remove the tar film, then do one of the above.
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor. https://archive.org/details/@horun
FYI, the first post on this thread got deleted, user banned.
The contents of the first post on this thread were identical to the first post of the other comment thread with the exact same title.
Getting rid of cigarette smell from cables
Merging the threads or deleting this one would be a good idea .
Do not ask Why !
