First post, by Nemo1985
Hello people, I recently bought this scsi cd reader.
Unlucky it the seller didn't care about the package so I received it with several smash on the fron panel (some cracks).
Even the tray has a small crack.
I already sent a message to the seller claiming that I would have tested it.
Now I did.
The slow speed is very low, in a 80 min cd it it begins around 10x and then it decrease to 8x, but it's unable to read at more than 10x.
Also when I put a cd in it makes a weird noise like if it was spinning without cd and then there is an high pitch whistle.
According to the review it was much faster than this: https://www.cdrinfo.com/d7/content/plextor-ul … i-cd-rom?page=1
What could I do about it? I tried to open it and despite some dust everything seemed in order.
Just to be sure: the rest of the config it is beefy enough: Adaptec SCSI Card 29160 in a pentium 4 build with windows xp.
Reply 1 of 4, by Horun
What do you have the "sync rate" set at in the Adaptec "SCSIselect" ? For the narrow 50pin UltraPlex it should be 20, for the wide 68pin version should be 40 (for the Plex's scsi ID).
Reply 2 of 4, by Nemo1985
Horun wrote on 2022-09-10, 16:20:
Yes I have, it is 20. I also have a Plextor SCSI cd burner (PX-W8220Ti) which sync at 10, but it's still faster in reading than the cd drive.
I fear that it has some sort of mechanical issue or the crack in the cd tray may cause higher vibration during the read, I also noticed that the laser mechanism (which moves on 2 tracks sometimes has issue to move, probably it needs some lithium grease), the third thing I noticed is that the spinning rotor is quite slow, but I do not know how to lubrificate it.
Reply 3 of 4, by Nemo1985
I bought another PX-40 TSI but also this one reads the disc at 8x maximum speed, for the whole surface.
This is madness...
I switched the scsi card from the AH-29160 to a el cheapo Adaptec ava-2904, restored the options with plex tools and it apparently solved the issue, but if I install back the AH-29160 it slows down again.
Any help?
Solved: I updated the windows xp drivers with the latest version from Adaptec and now it works like as intended, it was a known issue:
Windows XP: […]
Windows XP:
Driver Name: ADPU160M.SYS (Ultra160)
Addressed Issues:
- SCSI Hard Drive LED now stays off during Standby.
- Resolved an issue where the driver only negotiates to
asynchronous/narrow speeds to any non-hard disk device (CD,
tape drives, etc.).
Reply 4 of 4, by Horun
Nemo1985 wrote on 2022-09-16, 17:58:
Windows XP: Driver Name: ADPU160M.SYS (Ultra160) Addressed Issues: - SCSI Hard Drive LED now stays off during Standby. - […]
Windows XP:
Addressed Issues:
tape drives, etc.).
Glad you figured it out and Good info thanks !
