First post, by gabimor
Hello!
As you know, cable management is very hard in old cases, like Cooler Master Centurion, for example.
I'm trying to work, only, with the essential connectors in my PSU.
I'm trying to adjust the lenght of a SATA Cable, too.
While modding this SATA Cable, I forgot to identify the black wires.
I don't know which one is paired with the 12v wire, and which one is paired with the 5v wire.
Can I, randomly, solder black with black, or I have to identify the correct black cables?
This is a modern PSU, and it's not group regulated.
Can you help me.
Thank you!
