First post, by opencomputedesign
I've got a socket 7 motherboard From a compaq (I don't know what model) that I've been thinking about using for a low volume archival computer (E.G. for copies of my most important documents and photos).
My reasoning being that nearly every computer I've had die (with the exception of accidental physical damage) has been from bad BGA solder joints or bad capacitors. And this board has no BGA, and only a few easily replaceable capacitors. So I figure if I build this system up with max RAM, an AMD k6-2, and a couple of (as recent as possible) hard drives in RAID, and a faster USB card or ethernet card, it oughta go forever with very little maintenance as a semi offline backup. I of course realize that disks are the most important part of data backup, but having a reliable base system is both convenient and reassuring.
So I guess my question is, is this totally dumb and misguided?
