First post, by Bakersor
Hi guys, I got my hands on a Fujitsu Siemens Esprimo E5700 that outputs no video and I am trying fix it. The mother board model is D2334-A11, has embedded VGA, 2 PCI slots and a PCI-E (that allows ADD2 only).
I tried onboard VGA, PCI video card on both of the slots and I get no video output. CMOS battery reset and RAM change/swap did not work also. My diagnosis card shows code C0 and it gets stuck there, which for Phoenix BIOS it means 'Try to boot with INT19'.
I have tried putting in a BIOS update floppy hoping it might change something. I can hear the floppy being read, code being the same, still no video.
Do you guys have any suggestions?
Thank you.
Reply 1 of 2, by waterbeesje
You did say you performed a battery reset.
Did you also replace it? Some computers just refuse to boot when there's not enough voltage to driver the clock.
Are there any peripherals connected?
I'd suggest to test with only a floppy and hard disk connected. Nothing else.
Stuck at 10MHz...
