First post, by BreakPoint
I have some troubles with ATC-2455 (3dfx Voodoo 2).
It send my Win98 to BSOD every time I execute any glide app (wizmark and nature). I tried original 3dfx driver and FastVoodoo. Do i heed "genuine " ATC driver or board is dead?
My CPU collection - Looking for hardware in Ukraine - Ukraine vintage PC forum
Reply 1 of 3, by Meatball
BreakPoint wrote on 2022-09-12, 12:46:
I actually just received this exact model as part of a video card lot I bought. I tested it with the DirectX 7 Beta and FastVoodoo drivers, and it worked fine. No special setup/configuration required.
I'm not aware of any Glide specific benchmarks. Wizmark uses Direct3D. Try running "Unreal" or "Turok" or some other actual Glide capable game.
Otherwise, before giving up on the card, it could be you are experiencing some DirectX issues. Perhaps remove the Voodoo (or disable Direct3D) and try out your primary card (is it capable of 3D)?
Reply 3 of 3, by BreakPoint
After few changes in setup I managed to execute wizmark. But half of textures are missing. So yes
rasz_pl wrote on 2022-09-12, 13:36:
as most voodoos probably needs good resoldering
