First post, by dstaley
I know that the last officially supported Nvidia GPU generation for Windows 2000 was the GeForce 7 series of GPUs. I also know that at least one person has successfully run a GPU from the GeForce 200 series on a stock installation of Windows 2000, leading me to suspect that there may be support for the generations between 7 and 200.
In the case of GeForce 200 support, it looks like above linked post has success using the 197 drivers, albeit the Nvidia Control Panel application relied on syscalls that weren't introduced until Windows XP. This makes me believe that there's probably a combination of a newer-than-GeForce-7 GPU and older-than-197 driver that would result in a fully working system on Windows 2000 (including Nvidia Control Panel). For example, the 178 drivers were released a little under two years before the 197 drivers and support the GTX 280, so I guess it's theoretically possible that those drivers don't rely on Windows XP syscalls for the Control Panel application.
I'd love to hear more stories about running these "unsupported" GPUs on Windows 2000 without the use of modifications like the Extended kernel.
