First post, by audiocrush
Hi there!
today I found what appears to be a NuBus graphics card.
Maybe for a Apple Macintosh II?
I have no older macs than G3, so I have no clue what it could be.
It is made by Sigma Designs in 1989
It bears no apparent model number other than CMA-M2-0024.
There is nothing written on the back, and in the front there is 6 big QFP chips.
3 of them are the same IDT75C458 !!triple!! 8-Bit palette dac (which is weird because I assume you only need one of these for RGB)
and 3 others seem to be custom Sigma Designs silicon labelled 53C328 which is impossible to find.
Very grateful for any info on that thing!
It is unfindable to me 😁
Cheers
audiocrush
*edit*:
There is vy the way a whopping 24* MT 42c4255z RAM chips on there.
The datasheet suggests that it is 256Kx4Bit fast page memory
That would equate to a whopping 3 MegaBytes Ö_Ö can this be true?
That would be quite high end for a graphics card in 1989
https://www.nerdsh.org/ - my blog, a bit neglected though
https://www.youtube.com/channel/UChsU6woi3lhLhtT_ILbSCCw - Some videos of mine
Reply 1 of 5, by pentiumspeed
Could be editor's monitor or artist's graphics creation as it needs to be high resolution and drives the Apple monitor or Mac third-party compatible monitors. Is the connector 15 pin? Then that is for Macs with nubus bus slots. Mac II, Mac IIfx, Mac CX, Mac ci etc.
Could not find any details on Sigma Designs 53C328 chips.
Cheers,
Great Northern aka Canada.
Reply 2 of 5, by rmay635703
Sadly sigma has never had a comprehensive list of devices made, everyone knows who they are but no one has bothered to make an archive of the things
Sigma Designs pitched monitors at both the Mac II and SE as well:
Sigma Designs will exhibit its LaserView Display System, the highest resolution (1664 x 1200) monitor and display board system available in non-interlaced mode for Desktop Publishing and Engineering. LaserView monitors come as 15″ or 19″ landscape models and provide useful features such as dual resolutions, multiple cursor sizes, switching between screens, screen-save timer, and others. The LaserView Display System works with both Macintosh SE and Macintosh II.
Reply 3 of 5, by BitWrangler
24bit color = 8 bits per channel, R+B+G.. though the apparent 1Mbyte for each channel don't sound like much at 1 byte per color pixel, unless it's only a line buffer not a frame buffer.
Reply 4 of 5, by Horun
Interesting. just got off work and cannot help much but here are the Sigma websites: www.sdesigns.com/ before changing to www.sigmadesigns.com
http://web.archive.org/web/19961219175311/htt … w.sdesigns.com/
Unfortunately most of their old stuff was on ftp. Is all I have on quick look, I do have an old ISA Sigma VGA card but never found anything about it either...
Reply 5 of 5, by audiocrush
BitWrangler wrote on 2022-10-14, 04:16:
Yea I get that, but those are 3 triple 8-bit DACs, so 3x 3x 8-bits, which would be 72bits in total. That seems a bit weird to me.
Also the amount of memory surely doesn't seem like much at first, but considering the time this card came out, most of the cards went with a lot less.
I have a very high end IBM PS/2 XGA card of roughly the same vintage that comes with 1MB, half of which is an optional add-on board which is as long as the card itself 😁
From what I can find in old magazines like macworld, there used to be several products like Silverview, Pageview, Laserview and Colormax.
I'd rule out the Laserview from the start since the ISA version looks significantly different than mine. Only has one large Chip compared to the 6 big QFPs on mine.
https://www.ebay.com/itm/334581088342?hash=it … =p2047675.l2557
My best guess would be the ColorMAX, since it also kind of fits best to the "CMA-M2-0024" model-number.
https://archive.org/details/MacWorld_8901_Jan … /2up?q=colormax
Can't be sure though...
Also very weird, the prices range all the way from roughly 1500 to over 6000$ I guess card and monitor. Most were around 5000$ in magazines from '89.
I guess thats why there is not many of them around...
Well anyways, since I have no means to test it, at least I had some fun digging in magazines for information about it 😀
I did put it on ebay for auction now if anyone is interested in playing around with it.
