Excellent!
Your adapter looks pretty basic, should be an excellent model to study for a minimum requirements.
If you feel super adventurous values of all the components would be handy.
And if you are really bored, you could study where everything seems to be going. That may be kinda difficult though if it is more than 2 layer. Is it? I assume it probably is.
I suspect someone may pop up here soon who has actually worked on their own design for these slotkets. (There are at least two people around here who have.) And share with us the details of those components. Just like many of my other projects I’m starting from almost scratch here. So the usual process will probably follow, many alphas as design is researched, layout is researched. And once something seemingly possibly functional is taking form I’ll start calling it a beta, at some point I or someone here will prototype one of the betas, and more changes will probably be made based on the prototype. Depending on how everything looked there may be more prototypes. If all looks good then finally pi.0 will be released.
I can probably start an alpha for the edge connector and socket at some point soon, and map out the nets. In the meantime anyone willing to help, let’s try to understand fully what all those ICs are for and what they connect to.
Perhaps a crude alpha will come first, and once a basic design is formed we can start adding advanced features like those described in the socket 370 tweaker thread.
After a lot of thought I think I will probably start work on the slotket 370 (this one) first. And later on can apply what we learn here to the 370 tweaker.
I’m also thinking a onboard voltage regulator may happen on this one using a murata, or a pair of murata modules. As apposed to the usual strategy I have been using of making the power external. The reason for this is there is a fair amount of room available on a slotket. 😀
Also,
Thanks to wiretap for forwarding a socket datasheet link:
https://www.mouser.com/ProductDetail/TE-Conne … u5qjsQLew%3D%3D
