First post, by eton975
Hi, last month I received this motherboard paired with a Pentium MMX 200. I have since updated the bios with Jan's modded J.2 version. I then upgraded it with a K6-2/500AFX (running at only 400MHz due to 66MHz bus limitations and the 6x multiplier limit). I am using 128MB SDRAM (2x64MB high density sticks) and a Corsair CX500 with 20A on the 5V rail as PSU. OS is Windows 98 SE.
Currently I am using a Matrox Millennium II paired with an Orchid 3dfx Voodoo for video. While a razor sharp and fast 2D card, this combo is very lacking when it comes to later 3D games. I would like to keep the Voodoo as a secondary card for games like EF-2000, Tomb Raider etc that use Glide or 3dfx-specific programming, but I would like to change the Matrox out for an ATI or NVIDIA . I would be playing games like Quake II or III, American McGee's Alice.
I tried a HIS Radeon 9250 (expensive!) with the universal PCI connector and it would not POST in this system. It is not a faulty graphics card, it works fine under Windows 10 in my more modern ASRock 980DE3/U3S3. So I am pretty reluctant to try another Radeon 9250 or 9000 series unless this one just doesn't have the right voltage regulation circuitry or something to step down 5V to 3.3V.
Currently I have my eyes set on the Radeon 7000 PCI for this board, but if this is not an option I am open to the NVIDIA TNT2 M64 or other options. Does anyone here know what the fastest and most compatible option is for a K6-2 at 400MHz? Does the card vendor or amount of RAM matter? (besides the ones with a BIOS for Macs of course) Of course, it can't draw too much on the 5V or 3.3V rail, but I am not running a power-hungry Athlon to be fair.
If nobody here knows I have ordered a cheap POST card off Ebay with an LED that indicates 3.3V support, but it's nice to make sure before I spend nearly 100 more AUD on a graphics card that may not be compatible with this motherboard's PCI voltages or PCI spec revision.
As for why I am doing this when I could run the games on a modern system easily, it's just fun getting stuff to work and you also get a unique feel running at a lower framerate at a natively supported lower resolution. Sounds odd, I know, but this is VOGONS where people could probably just use emulators for most things if they didn't care about authenticity and the unique soundfonts of old sound cards.
Thanks for taking the time to read this and perhaps respond.
Reply 1 of 4, by leonardo
eton975 wrote on 2022-10-21, 10:21:
Hi, last month I received this motherboard paired with a Pentium MMX 200. I have since updated the bios with Jan's modded J.2 ve […]
I'm running a Voodoo3 with a 430TX-based ASUS TX97-XE and AMD K6-III+ and it's a very good pairing.
Since V3's are now priced like dinosaur-eggs, a PCI based RivaTNT/TNT2 might be a better option. It would be really close to the Voodoo 3 performance-wise and have compatible drivers game/time-wise. A TNT2 M64-version is basically as fast as first gen TNT, maybe a little slower - so not as fast as a V3.
A Matrox Millennium G400 is a little faster than V3/TNT2, but is fairly hard to find. The G450 is a clock-reduced version - roughly in the same performance category though.
A faster card like a GeForce 2 MX PCI might still work really well for a system like yours. Some ATi cards pre-Radeon might be comparable in performance, but the drivers back then were so hit-or-miss I hesitate to recommend them. Radeons on the other hand are starting to be too modern (as you're finding) and will likely be bottlenecked severely by the CPU even if you get your system to boot.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 4 of 4, by dionb
With those games, your VGA / 3D is the last of your worries 😮
Quake 2 might perform acceptably with a good 3D option, but Quake 3... Take a look here:
Sharing my benchmark results on a AMD k6-2 with various AGP cards
That's 500MHz on a 100MHz FSB board, so CPU is clocked 25% faster and cache, bus & memory 33% faster than in your case, and video goes via AGP, not PCI - It's entirely likey your results will be at least 25% slower. In these benchmarks the results are competely CPU-bottlenecked at anything over a TNT2-M64 and even with lowest settings he only hits 39fps. If scaling is linear you can expect max 30fps regardless of 3D option and I fear scaling may be worse than linear.
I fully realize back in the day we accepted lower frame rates than now (I ran UT on a K6-2 350 with ATi Rage Pro Turbo when I couldn't afford anything better. "It ran" is the nicest thing I can say about the experience), but with the luxury of hindsite - and over two decades of increasingly smooth framerates - I really don't think you will be doing yourself any favours with making this a period-correct low-end upgrade build, the sort of thing someone without enough money for a full system replacement in 1999 might have bought. If you want to play those games without ruining your nostalgia, go for a faster build (I find my Tualatin 1400S still a bit lacking in Q3A - that game really likes fast CPUs) and/or dedicate this machine to a really good experience on DOS or Windows 95 stuff.
