First post, by LeCroebar
Hey friends!
I have the (pictured) card. I downloaded the Diamond_Stealth_64_DRAM_Win_3.1_driver_v1.22 driver from VOGONS, it installed but after setting the resolution and a custom monitor (with specs that I know are valid) the system hard-locks when entering Windows and has to be reset.
I know there were a lot of "Diamond Stealth 64 DRAM" cards with all sorts of changes. I cannot for the life of me find any other drivers, though.
Also, not to brag, but I've got a BLISTERING 2mb of DRAM in this hot-rod!
Would any of you happen to have the correct Win3.1 driver for this card or a link to a place that has different drivers? I've tried a generic S3 Trio64 driver as well, and though it doesn't lock, I get no picture in resolutions above 800x600. This is on an Acer AC713 monitor, which I'm sure is PnP, but supports a lot of refresh rates and resolutions beyond what this card can do.
(thanks Cyrix200+ for the image from your thread)
[EDIT]
For anyone else having this issue - Download the Diamond Super CD, it has the right drivers under .\INSTALL\GRAPHIC\STEALTH\64DRAM
