First post, by Kahenraz
It seems utterly bizarre that I can't seem to find one. There are tons of PC Card (16-bit/ISA) adapters, but I can't find any CardBus (32-bit/PCI) adapters. Without support for CardBus, these adapters are going to be dog slow.
I'm using the presence of the metal grounding strip on the end of the card to identify whether it's CardBus or PC Card. I don't see this metal strip in any of the ones that I've been able to find for sale.
Reply 2 of 18, by bakemono
Yes, I have one which is Lexar branded. It is faster but not super fast (6MB/s). And unlike the plain 16-bit PCMCIA ones, it needs drivers installed rather than using a generic driver.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 4 of 18, by Kahenraz
That was my thought as well. Where are all of the UDMA compatible CardBus adapters.
I guess most of them were made for cameras that just didn't need it.
Reply 5 of 18, by Kahenraz
I managed to snag one of these today for way too much money. My curiosity got the better of me and I want to see how it performs.
The attachment Screenshot_20250121-211832_eBay.jpg is no longer available
I also found these all over eBay. They appear to be NOS. Does anyone know why they are so stubby? They are shorter than a standard PCMCIA card.
The attachment Screenshot_20250121-212818_eBay.jpg is no longer available
Reply 6 of 18, by darry
Actual CARDBUS eSATA II adapters do exist. I have some. Mine are Dynex branded. I don't remember the chipset and I do not recall exactly how fast they are but, AFAICR, they were fast enough for SATA hard drives.
If they work with SATA to IDE adapters, a passive IDE to CF adapter should work cascaded after the SATA to IDE adapter. Hopefully, (U)DMA would work too.
Reply 7 of 18, by Kahenraz
The advantage of it being an all-in-one adapter is that it isn't hanging off the side of the laptop. This is the same reason I never used eSATA.
Reply 8 of 18, by sangokushi
Kahenraz wrote on 2025-01-22, 02:29:
I managed to snag one of these today for way too much money. My curiosity got the better of me and I want to see how it performs […]
The short one is for machine use:
https://www.amazon.com/Davitu-Motor-Driver-co … 0/dp/B09FSX6T5Z
Reply 9 of 18, by Kahenraz
The gold connector suggests CardBus but the label says PC Card. I wonder which it is.
Reply 10 of 18, by weedeewee
Kahenraz wrote on 2025-01-22, 17:00:
Looks like cardbuspc-card? by looking at the sides.
fyi https://en.wikipedia.org/wiki/PC_Card#Bus looking at the photo...
is the wiki correct? I thought it was the other way round. the silly wifi card I based this first on is apparently a pc-card, not cardbus. No I know. :-p
Do not ask Why !
Reply 11 of 18, by wiretap
They're made to go in semi-modern CNC machines and several other types of industrial machines. They are half length because the card usually slots in perpendicular to the face of the control panel with a water/dust/oil proof door that closes over it. Having a full length card would mean they probably would have to increase the depth of the control panel.
My Github
Circuit Board Repair Manuals
Reply 12 of 18, by dionb
"PC Card" is generic, could be either PCMCIA (16b) or Cardbus (32b).
Reply 13 of 18, by Kahenraz
Are you sure? I thought PCMCIA was the form factor and PC Card was 16-bit and CardBus was for 32-bit.
Reply 14 of 18, by sangokushi
Any chance you ran speed test for this adapter?
Reply 15 of 18, by Kahenraz
Not yet. I just came in the mail yesterday. I have a non-CardBus adapter on its way too, for comparison.
Reply 16 of 18, by Majorianus
Kahenraz wrote on 2025-02-02, 03:16:
I had to create an account for this, since I have been wondering the same question. So, have you had time to test the new adapter yet? Results would be very interesting, if of limited practical value for most people.
About the PCMCIA / PC Card / Cardbus naming clusterf***. The original name of the standard was PCMCIA, which was also the name of the trade association that developed it. Soon they started to worry that there might be some confusion if the name of the organization and the standard was the same. So, PCMCIA contacted IBM for permission to use the "PC" acronym, which was trademarked and heavily enforced by IBM. They got the permission (presumably paid something for it) and renamed the standard to PC Card, while the hardware spec remained essentially the same.
However, it was too late and PCMCIA stuck until a few years later they developed the new 32-bit Cardbus standard based on standard PCI. The name of the actual standard and cards remained PC Card. Cardbus was just the name of the new 32-bit interface, which as you know was backwards compatible with the 16-bit "PCMCIA" PC Cards. Some people started to think that PC Card meant only the new 32-bit cards, since nobody used that name before the 32-bit Cardbus interface was adopted. To add more confusion, others just continued to call it PCMCIA whether they were talking about 16-bit or 32-bit cards. Thankfully they were a minority, but that didn't improve the messy situation much.
Reply 17 of 18, by Kahenraz
I tried the CardBus adapter today in my Windows 98 laptop, but found that I'm missing some kind of driver (Slot 2). Notice the other slot (Slot 1) works just fine, and is using a generic 16-bit adapter. The 32-bit adapter seems to need some kind of driver.
Does anyone know what that driver might be? Maybe it requires a newer version of Windows?
The attachment 20250609_235807.jpg is no longer available
Reply 18 of 18, by darry
Kahenraz wrote on 2025-06-10, 04:01:
Cardbus devices are essentially PCI devices, you can think of the Cardbus adapter as PCI IDE disk controller with adapted IDE to CF slots. PCIList under Windows 9x should give you the IDs needed to find a compatible driver among known potential drivers from third parties, if one exists. INF modding may be required or it might be possible that no Windows 9x driver exists .
See also this thread:
Abysmal performance of Compact Flash card through PCMCIA
